Engine backfiring
Old Jul 28, 2010 | 02:22 PM
olemissgrad's Avatar
olemissgrad
3rd Gear
Default Engine backfiring
Hello -- I own a 1997 Harley Dyna, my first HD. Bike is naturally cold-blooded but yesterday while in fifth gear, I noticed it missing (sputtering) and popping quite a bit. A fellow rider suggested the negative battery cable could be loose. Any other possibilities?
Old Jul 28, 2010 | 02:24 PM
tombeving's Avatar
tombeving
Check that your exhaust pipes aren't loose. This can cause popping.
Old Jul 29, 2010 | 01:05 PM
peppi's Avatar
peppi
You could have a loose or bad plug wire. check the battery terminals to see if they are tight.
Old Jul 30, 2010 | 08:59 AM
otlawpan's Avatar
otlawpan
Also check for an intake leak.
Old Jul 31, 2010 | 07:53 AM
olemissgrad
3rd Gear
Thanks, will check terminals today. Thing is, this only happens when I start off, then once it settles down, no problem.
mrhistory2012
Jun 21, 2015 10:10 AM
parrettdl
Sep 7, 2014 01:38 PM
olemissgrad
Exhaust System Topics
Jul 29, 2010 11:52 AM
jd140400
Nov 17, 2008 05:08 PM
Jimi D Pirate
11
Sep 18, 2008 01:25 PM
