Adjustable push rods...
Old Mar 15, 2011 | 06:06 AM
Jazzhog's Avatar
Jazzhog
Cool
Originally Posted by 1550vt
Jazz....if you want to PM me with your e-mail, I will send you a document that will step you through the adjustment procedure on any brand of rod. It is very detailed and if you follow the instructions...you can't mess it up.
OK... Lay it on me Bro, I'll give it a shot. Jazzhog@gmail.com Doesn't sound to complex from what I'm hearing. All I needed was a good swift kick in the butt to get me motivated. Thanks for the feedback fellas...
Old Mar 15, 2011 | 02:39 PM
Jazzhog's Avatar
Jazzhog
1550v
I got the instructions for the PR's. I'll study them and then attempt to do the job. Thanks again
Old Mar 15, 2011 | 03:57 PM
Faast Ed's Avatar
Faast Ed
I just reread the first post and realize how old the bike is.
You likely have the old plastic breathers in your rockerboxes. They are cheap to change for the metal ones. (the plastic ones warp with age). The metal replacements are inexpensive.
Point being, you might want to go the rockerbox route, and stay with your stock pushrods. You can upgrade the breathers and still be money ahead, even after buying gaskets.
Assuming you are doing the work yourself.
Old Mar 15, 2011 | 11:16 PM
marine30411's Avatar
marine30411
Stage I
can i get a set please thx marine3041@verizon.net
Old Mar 15, 2011 | 11:31 PM
$tonecold's Avatar
$tonecold
I would go with Screamin' Eagle ez install pushrods, preferably the tapers (it's what I am using). They come with what you need to make the original pushrod covers work and a very good set of instructions. They cost about $125-135. It's not a difficult procedure, take your time and you'll get through it ok.
Old Mar 17, 2011 | 05:19 AM
Jazzhog's Avatar
Jazzhog
Cool
Stonecold54, Would you happen to have the part number for the SE set? That sounds like the ones I'm looking for. Especially since I can re-use the original covers. Thanks
Old Mar 19, 2011 | 04:59 AM
Stubby3492's Avatar
Stubby3492
I have the adjustable pushrods, and stock tubes, and I had a bitch of a time trying to get them to stop hitting the inside of the tubes. Especially the front tube.
I took photos and did a sort of writeup of what I did. I have posted this before on the forum, but I'll post the link again in case it helps anyone out.
http://www.capitalhosting.ca/harley/valvetrain/
DieselDummy
Engine Mechanical Topics
37
Jan 13, 2023 08:07 AM
Mccula
EVO
30
Jun 26, 2019 08:21 AM
rydahog
Dec 7, 2017 04:44 PM
800screws
EVO
May 24, 2015 09:33 PM
emilyb
Jun 9, 2008 01:50 AM
