HD Adjustable Push Rods
Old Mar 25, 2011 | 11:03 PM
jlturner's Avatar
jlturner
Question HD Adjustable Push Rods
What is the proper adjustment on HD install on 96 motor? I installed with TW6-6 Cams @ 2.5 turns. I hear a little ticking??
Wonder if I should have went 3.5 turns??
Thanks
Old Mar 25, 2011 | 11:07 PM
luc.who's Avatar
luc.who
Thanks
I have the same cams on a 96, using the SE pushrods and adjusted 3 turns.
Old Mar 26, 2011 | 05:48 AM
Notgrownup's Avatar
Notgrownup
I have 3.5 turns on mine with Andrews 26H... ticks a tad but for most part is quiet...
Old Mar 26, 2011 | 11:00 PM
HardyHarHarley's Avatar
HardyHarHarley
If you are using the SE adjustable push rods, two and a half turns is not enough for most lifters.
I would adjust them three and a half turns and check for noise.
With some lifters, I've found you can adjust most noise out but you might need to adjust one or two lifters a half turn more than the other two.
Jim
JDG1172
May 7, 2016 08:53 PM
lhgdale
2014-2024 Touring Models
Mar 30, 2016 10:15 AM
73shovel rider
Mar 16, 2014 06:37 PM
remmag
Exhaust System Topics
11
May 26, 2012 08:19 PM
Bowhunter61
Apr 25, 2011 07:57 AM
