Starter removal 94 FXLR
Old Dec 5, 2012 | 08:34 AM
Caddo's Avatar
Caddo
2nd Gear
Default Starter removal 94 FXLR
Need to remove my starter on my 94 FXLR i think from what i've read is that i need to remove my primary clutch plate and drain oil, the take the bolt out of the jack shaft. Then i can take the starter bolts out and remove starter from right side of bike may have to loosen main oil tank in order to get starter out. Does this sound correct? One question will the jack bolt take a certain wrench/socket to get it off and also there was something about putting a new lock washer on the jack bolt and for sure get new tower gaskets. Does this sound right? My starter will spin but not engage may be the solinoid not kicking starter in.
Old Dec 7, 2012 | 07:08 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
If the starter is spinning, then the solenoid is working.
If the stater motor spins but the engine does not, the starter clutch is most likely the problem.
Remove outer primary cover, remove jackshaft bolt, starter mount bolts and wires and the starter is ready to come out.
Joe_G
EVO
Sep 3, 2017 08:37 AM
Hoosier bird
11
Feb 22, 2014 12:33 PM
Chummers
General Topics/Tech Tips
Aug 26, 2013 12:06 PM
SHVLrules
Shovelhead
May 6, 2012 01:25 PM
frantheman39
EVO
Aug 16, 2009 07:09 AM
