Bottom end / connecting rod limits
Old Feb 19, 2014 | 02:02 PM
soft 02's Avatar
soft 02
Id say go with the S&S crank and be done with it. Easy to spend someone else's $$$.
Old Feb 19, 2014 | 02:14 PM
ohioflhs's Avatar
ohioflhs
Darkhorse could answer all your questions. The tapered rods were found in the 96" motor and are junk.
Old Feb 19, 2014 | 02:18 PM
soft 02's Avatar
soft 02
Uh huh! They did change the design in 2011 though.
Old Feb 19, 2014 | 03:32 PM
Chaddilac's Avatar
Chaddilac
So is the new design better or still subpar?? Thanks again guys I appreciate your time
Old Feb 19, 2014 | 04:08 PM
soft 02's Avatar
soft 02
Better in that you dont have a bushing that can turn on you. Cast flywheels are not as good as they once were but thousands out there with no issue.
Old Feb 19, 2014 | 05:12 PM
Chaddilac's Avatar
Chaddilac
So to save money and have a better rod could I have my 88 rods pressed on a 96 crank?? And then have it welded
Old Feb 19, 2014 | 06:21 PM
HD Pilot's Avatar
HD Pilot
I have read a lot of threads about crank-work and practically no one seems to say the rods need replacing for a 107" build. I have a 2012 and my crank/flywheels should be coming back from Darkhorse soon with the stock rods. Not sure how different the 2006 rods are compared with the 2012s.
Old Feb 19, 2014 | 09:14 PM
BVBOB's Avatar
BVBOB
I have had it done many times and have another in the works right now, check out silvermooncycle on the net. Great work at a great price.
Old Feb 20, 2014 | 10:05 AM
djl's Avatar
djl
Yes, don't know if it will save any money but you could have the '06 rods installed on a 96 crank but the SE 4.375" crank assembly runs about $1100, plus shipping, from an online discount dealer. Send it to R/R for balancing and welding if you want it welded. The SE cranks are fitted with a tighter interfence fit than the stockers and welding for a street build may not be necessary; a judgement call. JMHO.
Butts05Train
May 30, 2014 07:02 PM
rockon
Mar 21, 2014 10:02 PM
999 Customs
Oct 11, 2012 11:42 AM
Bad Disposition
Exhaust System Topics
19
Sep 20, 2010 10:34 AM
'10NIGHTGLIDE
Aug 25, 2010 02:39 PM
