Cam cover
Old Apr 2, 2014 | 07:20 AM
nhrider1's Avatar
nhrider1
Originally Posted by 95ci springer
Ok but, when I pull the cam plate it will keep flowing?
If your bike is a Softail (and it looks like it may be... 95ci springer) yes the oil will continue to flow until the tank is empty. Softails have the oil tank above the crankcase so gravity will empty the tank unless you drain the tank first, or clamp off the oil lines.
Not so with Touring bikes and Dynas as the oil tank sits below the crankcase.
Old Apr 2, 2014 | 07:27 AM
soft 02's Avatar
soft 02
That is not true. The oil lines from the tank go to the pump and stop. That is why the tank has 3 quarts in it. If the oil stayed in the cam/crank case it would not be a dry sump engine. If the oil in the tank flows into the camchest when the engine is off then there is a problem with your cam plate/pump.
Old Apr 2, 2014 | 09:08 PM
GraemeR's Avatar
GraemeR
Oil will NOT flow out in a gush or stream...BUT it will seep through so you may need to plug a couple of oil holes while you have the cover off, otherwise you end up with a small puddle under the bike.
Once you have the cover off its fairly obvious which holes need plugging as they start to weep straight away.
Old Apr 4, 2014 | 02:45 PM
95ci springer's Avatar
95ci springer
I found out where to plug and now that I have the cam plate off with the oil pump still attached, will I have to re-center the pump on the crank shaft?
Old Apr 4, 2014 | 03:06 PM
soft 02's Avatar
soft 02
Yes if you removed it from the cam plate. They make dandy alignment dowels for this. You only need 2.
Old Apr 4, 2014 | 04:47 PM
95ci springer
It's still on the plate and I believe I bought the dowels you mentioned. However, I shouldn't need to do it then.
Old Apr 4, 2014 | 05:19 PM
soft 02's Avatar
soft 02
It is already centered to the pinion shaft so id say no need.
Mikeduke108
Jun 28, 2014 04:08 PM
HDmikie
May 3, 2012 09:23 PM
07RoadHawg
Jan 26, 2009 07:05 PM
sadavis73
Exhaust System Topics
Jul 7, 2008 07:36 AM
baggerman1964
Mar 18, 2008 10:19 AM
