Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hillside did my white FLHX 2011. i should be picking it up from Dyno tuning in Mechanicville . I can't wait.. i will post my graph when completed. 107 build, Stage II heads, 888 cams, V&H power duals and Oval slip ons, SE heavy breather. TB is stock at 50mm.
Scott did a rough dyno pull without a tune and number were 107/121Tq.. i still didn't ride the beast yet !!!!!!
Interested in seeing my numbers.....I think we'll be pretty close.
I was told by many very well known builders including Scott that the stock TB, although it could use some "cleaning up" is good for about 130 HP
That may be TECHNICALLY "correct", but since Harley itself includes the 58mm throttle body in its Stage 4 race kit, and since that throttle body is expensive and adds a lot of cost to the kit, I don't think they would have included it unless the improvement over the 50mm throttle body is notable.
I saw the price for the 58mm throttle body the other day in the Sreamin' Eagle catalog, and it was something like $500 as a separate purchase!!
