1997 Softail Custom forward cylinder cuts out
Old Apr 15, 2014 | 11:34 PM
Hard97softail's Avatar
Hard97softail
Stage I
Default 1997 Softail Custom forward cylinder cuts out
I have a 97 softail custom that I am having a problem with the forward cylinder cutting out. I can start the bike and it idles fine but when I put it in gear and give it gas the forward cylinder cuts out. I changed the plugs, wires, and was going to change the coil but if it was that I would think I would be having a problem with both cylinders. I did some research and it sounds like it could be the cam position sensor but its a little expensive to buy on a hunch. If anyone has had a problem like this and has any ideas even if its reassurance on the cam sensor I would appreciate it.
Old Apr 16, 2014 | 05:41 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Sure it's not an intake leak??
Scott
novaryder
Jan 6, 2015 08:12 PM
ChiroRick
Engine Mechanical Topics
Apr 24, 2014 12:37 PM
2007heritage
Electrical/Lighting/Alarm
Feb 16, 2012 06:44 AM
rickb0913
EVO
Jun 5, 2009 09:04 PM
Huebie
Jan 10, 2007 11:30 AM
