What to update in a 2009 FLHTC To bring it to the 21st centry
I would like to reduce the chance of failure in the engine so what would i need to replace to reduce the chance of failure.
Current engine
Revolution Performance 107 Kit 10.5.1
543 Feulings Cams
Adjustable Push rods
Stock Heads
Stock Injector
Air Filter (PRM Jet Stream Intake)
2009 Model (127-71578) SuperTrapp Kerker 2:1 SuperMegs for Harley Davidson FLH/FLT 2009 in Black Finish
ECU replacement (Thundermax)
So far I see I need to change.
Oil Pump for a High Pressure Oil pump
Rocker Assembly - Due to warping
Connecting rods
Oiler Cooler
Gear drive cams
Chain Tensioner - if not gear drive cams
What more do I need to change to make it more reliable?
Has your rocker arm support plate warped? Not a common ailment.
Connecting rods are not the best but if the motor is running OK with no issues; why do a complete tear down to replace them?
Oil cooler is always a good idea IMHO.
Gear driven cams and the SE billet plate would also be a good idea; upgraded oil pump is part of the 25282-11 kit.
It ain't broke...........................
Ok so cost wise, if I were to break this down into phases in relation to cost for work hours would I be right to say the following
Low workload
Gear drive cams
High Volume oil pump
Billet Cam Plate
Rocker Assembly
Lifters
Medium WorkLoad
Oil Cooler
High Workload
Dark horse Crank Balanced
Connecting Rods
Fly Wheel balancing
is this an accurate assumption?
Adding the oil cooler is a no brainer; doesn't affect motor operation but certainly can't hurt and could add to the longevity of the motor. If the lifters are noisy, replace them but what I am saying is that if there are no issues with the motor, leave well enough alone; no need to "borrow trouble".
Often times when one starts diddllng around with a motor that has no issues, the didling around introduces issues. So, I am back to "if it ain't broke.....................".
All im trying to do, is to bring the engine up to a technological standards that gives the engine more durability without having to spend hours in the service department.
For example. running your cams from a chain is so old school that most companies went away from this years ago. there are issues with the tensioners breaking to pieces for these chains causing massive damage.
1. Low pressure from the oil pump is approximately 3lbs at idle and 30's at running. Because of this when starting the engine and warming the engine up
it takes along time to pump the oil around the engine causing damage to the engine. When there is a fault with the oil pump a lot of times its hard to identify if there are any issues of it due to the low pressure of the oil.
2. Cam chain tensioner. These are small and not much surface area to them. Reading the complaints about then they have a tendency to self destruct causing the cam chain to cease. The plastic then ends up in the pump and throughout the engine needing a engine to be flushed and cleaned.
Resolution - Replace the chain cams to gear cams removes the tensioners and the slack issues in the chain when changing gears
3. The quality of the rocker assembly is not the best and it has a tendency of warping. to overcome this a better quality of rocker assembly should be fitted.
Now for my own personal satisfaction to have the engine run smoother as the tolerances from harley are massive balance the engine to create a smoother running engine with less vibration.
Just yesterday my mates harley was taken off of the road as the bike lost three mounting bolts as they were sheared off due to the vibration in the engine.
So I want to prevent this happening to mine.
21st century is a 2014 "A" motor. You already have that engine. You will NOT be making our engine into something it is not.
Why exactly do you THINK the engine needs more oil, anyways? Because a car engine does? Two vastly different engines. Our engine uses roller bearing for the crank and rods, wherein a car uses babbit type bearings. The only thing we could use more pressure would be to keep lifters pumped up. Stock bikes do well with the set up you have. 2009 is a good engine. Low oil does NOT hurt a roller bearing and whomever said it will? Thinks its a car engine that HAS to ride on a film of oil. Our bikes need no such film. Just a splash to keep the rollers nice and clean.
My advice is to quit reading the internet so much. All one reads is about issues, NOT about the thousands of bikes with no issues.
I, myself, have NEVER heard of 'warped rockers'. Not once. That's a new one on me.
If member DJL saying doing all of this work will introduce new issues, seems wrong to you? Well, let me repeat that, then. Don't mess with it unless you are going for a power increase and NEED some of these upgrades. And I do not mean a simple Stage1 or Stage 2.
This is why I am posting the questions.
The other harley is a low rider so if that is a dyna then yea.
I am also comparing the engine against its competitors and seeing where the differences are and why they say they are different to Harley, then looking into the reasoning why and noticing the common complaints for that engine.
So I am comparing the Harley Engine Against other American V-Twin engines like Victory, Confederate, Indian
thanks for your input.
