Replacing Engine Temp Sensor on TC
Old May 23, 2014 | 06:09 PM
jmr1971's Avatar
jmr1971
Default Replacing Engine Temp Sensor on TC
2004 Heritage
Replacing the engine temp sensor on my '04 FLSTCI, having a clearance issue getting to the deep 3/4" with a ratchet. Will a 3/8" drive joint do the trick or will I not be able to torque it enough to break it loose?
Old May 23, 2014 | 06:15 PM
senna's Avatar
senna
If it is the same as my 96" I used an extension, maybe 12 long or so.
Old May 23, 2014 | 06:22 PM
jmr1971's Avatar
jmr1971
The angle it comes off the front head keeps me from doing that because the rear head is blocking the use of an extension unless I use a joint. Don't have a joint, and I'm not sure I can reef on it hard enough with a joint to still break it loose because it won't be a 90 degree angle.
Old May 23, 2014 | 07:37 PM
wurk_truk's Avatar
wurk_truk
remove the horn bracket from the heads. That should give yo a bit of room. There is NO sealant (won't work with that crap) and it's not torqued all that much, either. If you can get a wrench or socket on it, it should go. They ARE dissimilar metals, but have not seen much corrosion.
Old May 23, 2014 | 09:11 PM
jmr1971's Avatar
jmr1971
I finally got it, thanks for the help. Engine temps now look normal and steady.
Old May 24, 2014 | 09:11 PM
wurk_truk's Avatar
wurk_truk
That should REALLY help out with you tune and tuning.
mke125125
Oct 27, 2023 07:53 AM
rsking45
Engine Mechanical Topics
May 30, 2023 11:40 AM
glsec507
May 16, 2017 02:49 PM
jmr1971
May 22, 2014 05:21 PM
alazlo
Jun 11, 2007 01:49 PM
