Roller Rockers
Old Jun 2, 2014 | 02:19 PM
Wmitz's Avatar
Wmitz
Default Roller Rockers
I am exploring upgrades for the bike, heads, cams, and a boost in compression via a 107 setup. If running a .590 to .625 lift cam are roller rockers necessary for a street setup?
Thanks
Old Jun 2, 2014 | 02:23 PM
djl's Avatar
djl
Not with 590 lift cams and most will tell you that rollers would be a good idea with 625 lift cams; I think that is debatable. I run TMan's 600SM cams with OEM rockers with no issues. I would probably try OEM rockers with 625 lift cams before spending the money on a set of rollers. Rollers will be noiser than OEM.
Old Jun 2, 2014 | 02:43 PM
prodrag1320's Avatar
prodrag1320
.590 is right on the edge,ide lean towards the r. rockers if I was building the motor
Old Jun 2, 2014 | 03:05 PM
Wmitz's Avatar
Wmitz
Thanks for the opinions, is the issue with the oem rockers to much friction or does the larger lift put to much side pressure on the guide due to the geometry?
Old Jun 2, 2014 | 03:12 PM
0ldhippie's Avatar
0ldhippie
I think .600 is the break point. I'm running them at .550 just because I had a set laying around. They make a little noise...
Old Jun 2, 2014 | 03:14 PM
soft 02's Avatar
soft 02
If on the cusp of roller rockers how about S&S's forged non roller rockers? They have longer bushings and are stronger than OEM?
Old Jun 2, 2014 | 03:48 PM
wurk_truk's Avatar
wurk_truk
I've tried those numerous times, trying to quiet a bike down. I never saw any difference over stock. What did help a very small bit was measuring the shafts and fitting the rockers as close as possible.
120r does not have rollers and thats good enough for me, BTW.
Old Jun 2, 2014 | 09:40 PM
Wmitz's Avatar
Wmitz
Truk, does the 120 have a different rocker assembly or is the same as a stock 103. Just curious.
Old Jun 3, 2014 | 06:32 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
On high-lift cams, the roller tip eliminates the increased scrubbing back and forth generated by cams of that nature.
Another aspect is the accuracy of the machined C/L of the roller tip.
Scott
Old Jun 12, 2014 | 09:39 PM
Eric Lis's Avatar
Eric Lis
Is there any particular reason this eng doesn`t have rollers? I have been wondering this since I have this engine, and the top end is rather noisy? They tell me it`s because of the steep ramp on the cams.
