Bore juggs .020 over
Old Aug 8, 2014 | 08:37 PM
nathanw's Avatar
nathanw
Default Bore juggs .020 over
What will happen if you bore your cylinders .020 but don't install new pistons to match, only new rings that are for .020 pistons? Seems like a recipie for problems, right?
Old Aug 8, 2014 | 08:49 PM
dan conner's Avatar
dan conner
you would think that those rings would break quickly. the cost to bore it out would probably be as much as a couple of new pistons...why not do it right? you should be able to find some used pistons at least.
Old Aug 8, 2014 | 09:02 PM
nathanw's Avatar
nathanw
This is something a friend of mine did and I told him I didn't think it was a good idea, I just didn't know what would actually be the end result.
Old Aug 9, 2014 | 07:01 AM
prodrag1320's Avatar
prodrag1320
let me get this straight,he kept the std pistons,bored it .020 and used .020 rings?? he`ll be taking it back apart soon enough.the rings wont last at all and like stated earlier,have a very good chance of breaking
Old Aug 10, 2014 | 08:19 PM
nathanw's Avatar
nathanw
That's what he said he did.
Old Aug 10, 2014 | 09:32 PM
djl's Avatar
djl
Somebody should take his motorcycle away from him.
Old Aug 10, 2014 | 11:33 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
The rings will very likely come apart the first time he hits the throttle. Then It's all down hill from there. Kinda' like a chain reaction type of thing!
Old Aug 11, 2014 | 06:43 AM
prodrag1320
WHY did he do this??
Old Aug 11, 2014 | 07:54 AM
soft 02's Avatar
soft 02
Be a true friend and weld his tool box shut.
Old Aug 11, 2014 | 08:08 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
It'll rattle and clatter, probably use oil, and perhaps smoke as well............other than that it'll run good............
Scott
