Rake and Trail
Old Mar 30, 2020 | 09:53 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Rake and Trail
I'm looking for frame specs on 98 Fatboy. Specifically the Rake and Trail as it comes from the Moco. I can't seem to find it anywhere If anybody has a link that can direct me I would appreciate it. I'm looking to put a wide glide front end on my bike and I want to see what it does to the Rake and Trail and what are the optimal settings when making these changes.. A good friend of mine has an FXSTC front end 32-in overall It's two over compared to a Fatboy and I want to put them on But I'd like to know what the OEM settings are first.. Thanks..
Edit: I've been searching for a few days now on the internet and the manual but I can't seem to find anything on it.... Thanks
Old Mar 30, 2020 | 10:34 AM
eighteight's Avatar
eighteight
FWIW, the 2000 model is 32 degrees rake & 5/8ths trail
Old Mar 30, 2020 | 10:59 AM
Racepres's Avatar
Racepres
I doubt the MoCo has a 5/8th trail on anything... that is a Dangerously Low number!!!!
Going longer, front end, can Only make for more Trail, which is Not a bad thing at all...just slower/heavier Steering!!
The MoCo Numbers, even on the exact same frames, are different due to different length front forks, rear shock height etc... Not Reliable is what I am Saying... like Believing there was More than one Rake on a 4-Speeed Shovel Frame....Nope!
Old Mar 30, 2020 | 11:14 AM
Architect's Avatar
Architect
Are you changing it to have a longer front end? Because you could probably do some Progressive drop in's and get her back down to the same length of your stock front end. My Black Wide Glide, she is 2 under to go along with the short rear shocks and keep the frame level. Then again, it may be a similar front end, maybe you just need trees with the same rake as your original and use your lowers and tubes??
Hard to say, not sure what your end goal is.
Good reading:
http://www.thompsonchoppers.com/rake...il-calculator/
Old Mar 30, 2020 | 11:39 AM
98hotrodfatboy
I wanted to change it up and give it a little more length. I'm going 2" over on the front and the trees that came on this front end are +3° so I imagine it will give it a little more trail but not a shitload because I'm changing the rake on it a little bit as well..
Old Mar 30, 2020 | 11:45 AM
Tom84FXST's Avatar
Tom84FXST
Pretty sure all softail frames were the same... and rakes for the different models was achieved though different trees...
32 degrees on the frame...some models had 2 degree raked trees...all springers have de-raked trees
Old Mar 30, 2020 | 05:13 PM
FreedomRider's Avatar
FreedomRider
1998 FatBoy had a 32 deg rake and a trail of 5.8 inches ... so the Model Lineup Book shows ...
Old Mar 30, 2020 | 05:33 PM
98hotrodfatboy
So if I was to go to a 2" over lenght tubes and a 3* rake in triple trees, do you think it would decrease my rake to less the 4"?
Old Mar 31, 2020 | 05:14 AM
FreedomRider
http://www.whosyadaddy.com/rake_trail_calculator.htm
I think you would be Ok ... I added a 4 degree tree and 2" over tubes to my Sporty and still have just over 3 inches of trail ... it handles good ... maybe the above link will help you ...
Old Mar 31, 2020 | 07:39 AM
98hotrodfatboy
I have used that exact calculator and I plugged in what I stated above my trail will fall below 3.7 and by what I'm hearing the Softails need to be over 4" and preferable 5" for stable handling. So it looks like I won't be able to use the front end my friend has because of the 3* rake in the trees. The other thing I noticed was that the offset in my OEM trees is only 1.45". And all aftermarket trees are 2.4-2.5" so I'm going to have to stick with 0* rake in the trees...
