Fat boy solid wheels on my 90 FLHTCU?
Old Mar 23, 2009 | 09:46 AM
mjunk1's Avatar
mjunk1
Default Fat boy solid wheels on my 90 FLHTCU?
Does anyone know if I can put those solid Fat Boy wheels on my Ultra? And if so, what mods or adjustments would need to be made?
Thanks.
Old Mar 23, 2009 | 11:06 AM
paco's Avatar
paco
mjunk1,
for timken bearing wheels it just a straight change out. (i think)
for sealed bearing wheels :
The rear is no problem. use the fat boy rt spacer- 1/2" and i think its 1- 1/8" spacer on the pulley side. the brake disc has to be shimmed about 1/16-1/8". the pulley has to be shimmed a fraction, can't remmeber the exact amount. I wrote it down some where. The front spacer on the rt side is 7/8" and the speedo unit i cut to 7/8". if you use the new front rotors you will have to cut a slot for the speedo unit to sit in. this is subject to error so it may be that you have to use spacers for your application. this is what i used when i put them on my 90 ultra. i am running streetglide wheels on my 90 ultra at the present time. same spacer sizes.
http://s119.photobucket.com/albums/o...EG%20-%2099RG/
later.........
Old Mar 23, 2009 | 11:15 AM
20NightTrain03's Avatar
20NightTrain03
going to have to lose the dual disk.....or am i wrong?
cuz i wanted to run fat boy wheels on my street glide so i thought about this
(yes i understand 99 earlier have different wheel bearings)
Old Mar 25, 2009 | 07:29 AM
paco's Avatar
paco
20NightTrain03
i did mount a brake disc on the fatboy wheel by removing the rt side wheel cover . there are threaded holes on rt side.
Old Apr 27, 2009 | 10:22 PM
johnnyQ's Avatar
johnnyQ
Default 2000+ wheels on 97 FLHT
Originally Posted by paco
mjunk1,
later.........
Paco, I'm trying to get 2000+ wheels on my 97 FLHT. Think all issues are resolved except the front speedo sensor. Would appreciate any more details on how you managed to get yours to fit.
John
Old May 4, 2009 | 07:11 AM
paco's Avatar
paco
Johnny Q,
remove the speedo drive unit and cut the unit down (on the side to the wheel) to 7/8". I used a hacksaw and a file to smooth it up. the total lenght of the speedo unit will be 7/8"...or take it to a machine shop and let them turn it down to 7/8". file or grind a slot in your 2000 disc for the speed unit clip and reinstall. the other spacer will also be 7/8" on the right side while sitting on the bike.
sorry for the delay but i have been busy on my 95 project. Hope this gets u going.
later....................
Old May 4, 2009 | 08:58 AM
johnnyQ's Avatar
johnnyQ
Thanks.. I'll try that
John
land of giants
Wheels/Tires
Oct 7, 2012 05:11 PM
Mike Willmont
Oct 11, 2010 07:40 PM
kjkustoms
May 10, 2010 03:30 PM
bad466
EVO
Jun 5, 2009 05:48 AM
Iceman
Jan 21, 2005 07:03 PM
