clutch rod adjustment
Old Apr 11, 2007 | 02:49 PM
ssls6's Avatar
ssls6
Default clutch rod adjustment
I've been reading my manual and the internet on adjusting the clutch rod. The procedures are leaving me a little confused. First off, the standard way to adjust (as I understand it) is as follows:
1) thread cable adjuster full in
2) back off clutch rod
3) extend clutch rod feeling it touch
4) repeat 2 & 3 a couple of times
5) back rod off 1/2-1 turn from touch and lock it down
6) thread cable adjuster back out until 1/16 cable slack.
The easy way is described as:
2) pull clutch lever back to grip
3) back off clutch rod
4) extend clutch rod feeling it touch
5) repeat 3 & 4 a couple of times
6) back rod off 1/2-1 turn from touch and lock it down
7) thread cable adjuster back out until 1/16 cable slack.
What confuses me is that the two methods are so different (lever closed versus lever full open). Which method should I follow or does it matter?
Old Apr 11, 2007 | 03:09 PM
louiep's Avatar
louiep
Default RE: clutch rod adjustment
Either of the two ways will get it done, the second one is just a bit easier.
Old Apr 11, 2007 | 03:46 PM
Hackd's Avatar
Hackd
Actually the second method that you posted is closest to the procedure that I use. Remember that it is supposed to be adjusted 'at room temperature' not just after running all over the country.
Oh...I use an allen wrench to set the cable endplay. Makes for a good Hack gage.
Old Apr 11, 2007 | 04:22 PM
mtnlvr's Avatar
mtnlvr
Is there a difference between the two?
In either one, aren't you adjusting the clutch rod the same as long as the cable is slack? Whether the lever is released or pulled wouldn't change anything...would it?
Old Apr 11, 2007 | 06:35 PM
ssls6's Avatar
ssls6
Yeah there is a difference. There are two adjusters for the clutch; the rod and the cable. Each adjuster has range of adjustment and the lever position determines how much of the rod or cable range of adjustment gets used. Do it by the simple method, and you almost run out of cable adjustment. Do it by the book, and you use a lot of the threaded rod. I just don't know if one is preferred over the other.
Old Apr 11, 2007 | 08:17 PM
mtnlvr's Avatar
mtnlvr
Where did you find the "easy way"? I'd likt to read a little more detail on it.
Old Apr 11, 2007 | 09:42 PM
ssls6's Avatar
ssls6
Here on this website in the DIY section.
https://www.hdforums.com/m_70839/tm.htm
I've now tried it both ways and I think I'm going to stick with the "by the book" method. I don't think it really makes a difference which method you use but I don't see how the "simple" method is any easier- just different.
Old Apr 11, 2007 | 10:44 PM
mtnlvr's Avatar
mtnlvr
Thanks for the link. I glanced through some of the DIY stuff but there's so much there.
I can see where doing it the "easy way" for a while you'll get "the feel" for where the clutch will start to engage or disengage. I'll give it a go the next time I adjust mine.
Old Feb 9, 2008 | 07:50 PM
92Fatty's Avatar
92Fatty
Thanks for link SSLS6 that method worked great and i found a whole lot more info on the forum. Thanks. Kent
Old Feb 10, 2008 | 02:15 AM
Classic Beast's Avatar
Classic Beast
Both are really the same the reason you pullthe lever in is sometimes when you back off the cable adjuster it will pop out and the cable isn't backed off all the way pulling the lever in just makes sure the cable is free before you adjust the rod. Just make sure when you adjust the rod there is free play as sometimes when you tighten the lock nut the adjuster will turn back in, you need the free play in the rod as when it all heats up the free play will be used up. The cable is adjusted last so the Clutch actuator has the correct range of motion.
