Aluminum cases
Old Nov 11, 2014 | 03:18 PM
flhchaz's Avatar
flhchaz
Default Aluminum cases
Hello all, My '97 flht has the plain old aluminum finish on the drive train and it could use cleaned up some. Has anyone had any good experience with any products that make the aluminum "bright" again? I've been down the S100 and nylon brush route, and am looking for something that will really clean/ restore it.
Thanks
Chaz
Old Nov 11, 2014 | 03:36 PM
Spanners39's Avatar
Spanners39
I use Solvol Autosol Chrome Cleaner.
Old Nov 11, 2014 | 03:48 PM
flhchaz's Avatar
flhchaz
Thanks Spanners. Do you use this on the textured surfaces like the inner primary and engine cases?
Old Nov 11, 2014 | 03:50 PM
Beemervet's Avatar
Beemervet
It's a cleaner not a polish.
Old Nov 11, 2014 | 03:52 PM
flhchaz's Avatar
flhchaz
Thanks. That makes sense. I did a Google search and only saw the paste. I'll look into that further. Thanks for clearing that up.
Old Nov 11, 2014 | 04:20 PM
Spanners39's Avatar
Spanners39
It is both in one tube and you can use it on rough or smooth surfaces as long as they are not so rough they rip the cleaning rag to shreds.
Old Nov 11, 2014 | 04:24 PM
flhchaz's Avatar
flhchaz
Thanks. I'm going to try it. I had a Kury inner primary cover on the bike for many years. I just took it off and need to really clean the inner prmary underneath.
Old Nov 11, 2014 | 04:44 PM
SeaZund's Avatar
SeaZund
I haven't tried it yet, but someone on here talked about this the other day
Old Nov 11, 2014 | 04:48 PM
flhchaz's Avatar
flhchaz
Thanks for the info. Happy Veteran's Day, THANK YOU for your service.
Old Nov 11, 2014 | 04:51 PM
machinehed's Avatar
machinehed
Default aluminum
My 90 FLT aluminum was beyond a good polishing so when i did a motor
rebuild my motor guy blasted them and i painted them using the VHT brand paint. I used the high heat , oven cured type and was impressed.
They have a wide variety of colors including aluminum and chrome .
Saved a lot of elbow grease trying to polish 25 year old oxidised aluminum.
