Not another cam thread😃
My engine runs remarkably smooth and this was commented on by a few people that rode my bike afterwards, who had nothing to do with the build.
I have read that head volume was something HD was sloppy with and there is more variation than there should be. Maybe when I had my heads milled, their volumes were measured and they are now more equal.
Regarding the adapter, it was because my bike is a 95 and it was a year that HD was changing the connector/number of pins. The actual module is the same and as luck would have it, the module I bought was not the right connector. The company that makes the module I bought makes an adapter, so that is what I went with.
I am not sure what to make about your cheating remark but will say what my thought process was. I wanted a bump in cranking pressure as Evo's respond very well to higher pressure. Also, depending on the cam selected, you lose some cranking pressure, so milling the heads gets some of that back. I went with the thinner gaskets so that if something unexpected happened, I would have the option of going with a normal thickness gasket if I needed to reduce the pressure some. I was also thinking in long term, if I would want to go with different Pistons in the future, it would give me some leeway to play with. Again, really not 100% necessary but just seemed like a cost efficient way to get a little more out of the cam.
As it turned out, there was some very minor cylinder scarring once things were opened up, so a fresh set of rings and minor honing and it was fine.
The cases were cleaned up where the jugs sit to ensure a good seal due to the age of the engine even though I really didn't have any leaks or weeping.
I am probably making smaller numbers than most guys on this forum but the way in which the power it is making is delivered and the unusual smoothness makes for a bike that is fun to ride all day without wearing out my aching arthritis body. It's comfortable around town, back roads, sweeping curves, and yes, interstates.
My dad has a 2008 Road King. I am not sure what all it has besides Rinehart's but on our last ride together he started to get on it a bit to pull away from me and I surprised him by not only keeping up but overtaking him. Granted, we were not going fast, but it was more of a roll on acceleration thing. He's 70 years old but I have more aching bones, arthritis, and other health issues than he has.
Sorry about going off on a tangent, but my point is you don't need to have the biggest numbers to have a bike that is responsive and fun to ride. You also don't have to empty out your bank account.
Tom
how about build another one the same way
