It definitly sounds more like a carb issue. All the Voes does is change the timing when it senses a vacumm drop. I would pull the float bowl clean it and blow out the jets with some carb cleaner. You did say you had no problem at 3k rpm. so it's not a fuel supply issue but more of an idle circuit issue and the Hiccup could definitly be an accelerator pump issue. Pull the air filter and check you pump operstion to make sure it's pump. That pump could also cause a hard start condition.
Hmm... good thought, didn't even think to check that. The carb is fresh and clean... It was rebuilt earlier this year when I rebuilt the motor, and I took it apart a few thousand miles ago to make a jet change. The accelerator pump has never been apart though. I will go get my FSM and see what it all looks like in there before I tear it off.
Ignition sensor in nosecone is brand new as well; last one melted from the heat of a busted cam bearing. Im really leaning towards the accel. Pump or plug wires now.
Make sure accelerator nozzle is pointed straight into the carb.
I don't think the accelerator pump would cause the engine to die when coming down from high revs. But! Who knows on these things.
Timing may have slipped since install of new sensor.
Bike was timed with a timing light; there is a possibility the adjustment screws came loose though. I will check that today.
It just makes sense that it's in the idle circuit because that is when the problems seem to happen, but I'm not ready to rule out the VOES and old *** plug wires just yet. Accel pump worked fine last time I checked it but old things break.
Tman, you say when you hold the rpm a 3k for a while, and then close or chop the throttle, it'll die.
To rule out the VOES, ground the VOES wire and see if it'll repeat, or even take it for a short ride and see if the symptoms repeat, try not to let it ping on acceleration.
