VOES/Coil question
Old Nov 17, 2014 | 01:20 PM
  #41
br549A1's Avatar
br549A1
I bet when you cut yours open, if you do, you find some gas residue like I had. The only clean part on my bike when I bought it was the back piece of the petcock.
Old Nov 17, 2014 | 02:06 PM
  #42
98hotrodfatboy's Avatar
98hotrodfatboy
Default Voes woes
If you know it's definitely intermittent than I would just replace the entire ignition and get rid of the voes set up. You also mentioned that you have been in the carb before and changed jets. Is this when your idle problem started or,, why did you re-jet?
Originally Posted by tmanbuckhunter
Thanks, I may go Dyna S and forego the VOEs... Not sure yet. Would sometimes read up to two ohms.
Old Nov 17, 2014 | 02:29 PM
  #43
tmanbuckhunter's Avatar
tmanbuckhunter
You guys should really read the whole thread start to finish.
Jet changes were made thousands of miles ago... they are not the issue. Carb was re-jetted for a cam change etc... but that is not part of the topic. I'm still not doubting a possible plugged up idle jet and the VOES just happened to be broken too.
Old Nov 17, 2014 | 11:13 PM
  #44
D_gyver's Avatar
D_gyver
ok it took me a few days to respond to this on because I had to test my theory before I chimed in.
the voes is a simple switch its either OFF or ON I think we can all agree on that.
if your reading more than 0 ohms your switches contacts are failing or you have a shyty ohm meter.
ok on to what I tested the stock Harley ignition has a pullup resistor of 5 ohms in line with the IC so I I hooked a 50 ohm restrictor in line and it still triped the circuit then I installed a 100 ohm still worked.
so if your switch is reading ohms under 100 it will still work. but it is most definitely a bad switch.
I would replace the voes if its reading more than 0 ohms. replace the plug wires just because they are so old even if they are good now wont be long before they do fail.
next would be cleaning the carburetor a pluged pilot jet will cause your problem. like a few people have stated.
also a bad coil can cause this I had a brand new coil fail on me a few months ago it tested good it sparked good on my air gap gauge and the ohms were right. it ran fine going down the road and most of the time it idled just fine. but when it would start messing up it wouldn't idle and would cough out the carb give it some gas and it would come out of it. as soon as I let off the gas it went right back to running like crap.
Old Nov 18, 2014 | 05:50 AM
  #45
tmanbuckhunter
Red face
Multimeter is a fluke that I used in a career I'm no longer interested in, so it's fine. The VOES reads under 1 ohm most of the time, but then it will read up to 2 ohms other times... it is def getting replaced.
Interesting thing you said about the coil, and I wouldn't doubt that mine is roasted either... almost 20 years old too. I'm going to replace the VOES, plug wires, and check to make sure my idle jet isn't clogged, drain the tank, clean petcock screen and see what that gets me. If that doesn't do it I will see if I can get a known good coil from someone to test out first before I buy one.
Old Nov 22, 2014 | 06:49 AM
  #46
tmanbuckhunter
Well, still in the garage on the jack. HD says my VOES is obsolete and I'm not sure I want to bother with the aftermarket ones... I don't trust the quality of them.
I guess it's time to find a Dyna S set up at a decent price.
Old Nov 22, 2014 | 07:00 AM
  #47
br549A1's Avatar
br549A1
Well, still in the garage on the jack. HD says my VOES is obsolete and I'm not sure I want to bother with the aftermarket ones... I don't trust the quality of them. I guess it's time to find a Dyna S set up at a decent price.
You guys didn't believe me! There's a colored dot on yours and jp sells replacements that match up. I think we have blue dot which is 4.5, did you check eBay? I got mine for cheap and it was brand new on tech hd box still. If it wasn't so damn right in there id mail it to you so you could ride. It's 15 degrees here. My season is over.
Old Nov 22, 2014 | 07:11 AM
  #48
Dr.Hess's Avatar
Dr.Hess
What are you going to do when you put that new ignition on and it doesn't fix the problem?
Old Nov 22, 2014 | 08:50 AM
  #49
tmanbuckhunter
I didn't say the VOES was the whole entire problem, and I happened to find it by chance because of the problem, but thanks for reading the whole thread.
You're real good at reading whole threads before posting Dr. Hess.
Old Nov 22, 2014 | 09:05 AM
  #50
FlamedFXR's Avatar
FlamedFXR
Then he will check compression.....
