brake light
Old Dec 21, 2014 | 03:19 PM
WVICEMAN's Avatar
WVICEMAN
Default brake light
Evening all, I was checking my lights today on my 85 FLTC and noticed when I use my foot brake I have no brake light but when I use the hand brake it's fine.....any ideas?
Old Dec 21, 2014 | 03:23 PM
Beemervet's Avatar
Beemervet
Rear brake switch or rear bulb.
Old Dec 21, 2014 | 03:24 PM
WVICEMAN's Avatar
WVICEMAN
I checked the bulb and it's good. Probably the switch.
Old Dec 21, 2014 | 03:51 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
First unplug and plug in the wires going to your inline switch and try again to make sure it isn't just corrosion build up.
Old Dec 21, 2014 | 05:34 PM
WVICEMAN's Avatar
WVICEMAN
Thanks Amigo, I'll check the connections tomorrow.
Old Dec 21, 2014 | 05:43 PM
dmg1029's Avatar
dmg1029
Pick up a small tube of dielectric grease to use on all connections. I'll be broken wire or connection. You might try jumping the brake light switch to see if its working.
Old Dec 21, 2014 | 07:22 PM
Tee&Vee's Avatar
Tee&Vee
Take off one lead only from the rear switch and see if your brake lights come on. This is a cheap and free test. On my Softail I jacked up the bike on a cinder block under each wheel and wood blocked the kickstand so I didn't have to take the exhaust off. The auto parts store switches are just zinc and will probably get rusty in a few years but then again they're only six bucks.
Old Dec 22, 2014 | 05:17 AM
Spanners39's Avatar
Spanners39
You need to join the wires to test the switch. If you replace the switch the brakes usually don't need bleeding afterwards.
Old Dec 29, 2014 | 10:19 AM
WVICEMAN's Avatar
WVICEMAN
Thanks for all the suggestions but I found the issue. I took the wires off and cleaned everything and then a little dielectric grease and brake light works fine. Nice cheap repair.
Half-Fast Deuce
Sep 23, 2012 07:56 AM
Deelux
Jul 30, 2012 08:40 PM
HemiGlide69
Feb 17, 2012 06:38 PM
daddiokool
Mar 21, 2008 12:11 AM
95Heritage
May 27, 2007 09:46 AM
