Which heads would you pick?
Old Dec 25, 2014 | 09:08 PM
Schex's Avatar
Schex
Originally Posted by Jerrysounds
145 dry. Thanks guys
Was that test with the throttle wide open?
Also with the amount of work on the heads, they may be set up to handle higher lift cams.
The W6H is a higher lift version of the W6 (.590) and will get you closer to your goal with the right compression.
Old Dec 25, 2014 | 09:16 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Default Combustion chambers
Depending on the configuration of the build it is necessary to reconfigure the combustion chambers to accept larger valves and higher compression pistons. I have not heard of a 1.925 intake most likely a 1.90 with 1.63 exhausts and depending on the porting they should flow upwards of 180 cfm. They sound very familiar to what I have in my build. Hillside Stage II heads. The changed combustion chamber can still accept a higher compression piston but most likely the dome might have to be milled to fit the chamber to maintain the proper clearance. I would bring them to your indy have them flowed and cc'd and then have him reccomend a higher compression piston that can be fitted. Hopefully they are around 84 cc. If so you will have a great start to a 90/90. Especially with a w6. However I don't care much for the Mikuni... good luck. will be following the thread to see the outcome..
Old Dec 25, 2014 | 09:21 PM
Jerrysounds's Avatar
Jerrysounds
Thank's Bagger, I was just on their web site and it looks correct to me. They look like the #4 heads and show 8.9-1 for the Evo. The .030 should get me to 9.4. Anyone know if substituting the cylinder base gasket with Three-Bond 1104 works as a good sealer and if it will help bring the compression up to 10 - 1 or is it not worth the possible leaking that will come a year down the road?
Old Dec 25, 2014 | 10:31 PM
Rhino-1's Avatar
Rhino-1
I'd stick with the .030 gaskets and not mess around with the three bond. Oh, and that Mikuni is a great carb with superb performance and potential. Very easy to tune...
Old Dec 25, 2014 | 10:40 PM
Jerrysounds
No. 10 turns of the starter for the 145lbs . I will take a look at the W6H but I have the w6 now so it it is close I will stay with it. Just depends on the cost/output. I will do it if I can get to 100hp without breaking the bank. A little extra info: I put the old heads up against the new .050 decked heads and they have the same deck hight. Thanks again for the info guys, Lots of good comments.
Old Dec 26, 2014 | 12:26 AM
D_gyver's Avatar
D_gyver
145 is way to low it should be closer to 200. at 145 your compression ratio is around 8:1 optimum static ratio for a W6 is 10.38:1
those head gaskets are probably on there for a reason when I use .060 head gaskets its because I trued the cylinders and the pistons now come out of the hole .010- .030 if they are like that and you put .030 head gaskets on it you will smash the pistons into the heads
show me picture of the combustion chamber and find out the cc of the heads and the bore and deck height of the pistons. with that information I can point you in the right direction.
Old Dec 26, 2014 | 03:49 AM
Dun Roamin's Avatar
Dun Roamin
those head gaskets are probably on there for a reason ...
Yah, I was thinking the same ... you didn't tell us the squish, did you?
Old Dec 26, 2014 | 06:32 AM
Schex's Avatar
Schex
Two things need to be measured to know what's going on here.
1)Head deck height off the fins won't tell you anything, combustion chamber volume has to be measured.
Get a piece of plexiglass or lexan, drill a hole in it, place it over the chamber with grease around the deck to seal it, and a means to measure how much liquid(rubbing alcohol) it takes to fill the chamber.
http://www.motorstate.com/CCHeads.htm
2)To measure piston deck height, drop the jugs on with no piston rings or base gaskets, get a straight edge and a feeler gauge to measure how much the piston is above or below the deck.
Measure this inline with the wrist pin, not like the picture below, because the piston will rock, and give inaccurate reading.
This will determine what thickness base gaskets and head gaskets could be used.
Old Dec 26, 2014 | 06:38 AM
Schex's Avatar
Schex
I don't think that 145 reading is correct, compression test with the throttle closed compared to wide open can make a big difference.
I was checking out a stuck auto compression release problem on my 111 the other day, and I get a 40lb difference in compression with throttle open compared to closed.
Old Dec 26, 2014 | 11:03 AM
Jerrysounds
I see you point on the tall head gasket guys, I will need to do the tests that Schex3x has suggested. Where did you get that measuring tube thingy? I want one I am going to use some puddy on the piston to find out what the valve clearance is. Also going to talk to Woods on Monday about the w6h. I really would like to get to 100hp now that Im in it. Many Thanks to all!
