Which heads would you pick?
Old Dec 26, 2014 | 07:21 PM
  #31
JohnMB's Avatar
JohnMB
No typo its the screamin EagleCV 45mm
Old Dec 26, 2014 | 08:12 PM
  #32
JohnMB's Avatar
JohnMB
Iam sorry 44 mm screamin eagle my bad
Old Dec 26, 2014 | 10:04 PM
  #33
LowriderHarold's Avatar
LowriderHarold
Default Branch O'Keefe Heads
These are pics , I saved from a seller on e-bay, few weeks back, trying to sell these Evo Branch heads. S&S Replacement Heads, ( which are what I have on the Lowrider) are almost identical. Branch claims these are 8.9:1 & the S&S Replacement's I run, are 8.8:1, 76cc. You can't run domed pistons with the S&S & I doubt if you can run domed with the Branch heads. Both have the bathtub shaped combustion chamber. Both are pricy, but the S&S make good power & believe these do also if set up , correctly!
Just read more in depth that Branch sells pistons to go with their #4 head sets & are possibly 30 deg domed.
Ride Safe,
Harold
Old Dec 26, 2014 | 11:27 PM
  #34
Jerrysounds's Avatar
Jerrysounds
Here should be a pick of the heads in question. Looks allot like yours Harold. Do you have a pic of the spring side. My spring setup looks different than stock too.
Old Dec 26, 2014 | 11:40 PM
  #35
Jerrysounds
Here is the spring side. looks like a different spring setup.
Old Dec 27, 2014 | 10:17 AM
  #36
LowriderHarold
Sorry. Don't remember if seller had pics of spring side & can't find the listing, anymore. Looks like you have Branch O'keefe heads. I would give em a call & see what pistons they have to go with em & go from there.
Nice heads to build around. Branch O'Keefe heads was what I had in mind to do, but I didn't wan't to alter my stock heads so I went with the S&S Replacement's & feel I made a good choice. Good Luck.
Ride Safe,
Harold
Old Dec 27, 2014 | 10:59 AM
  #37
Dun Roamin's Avatar
Dun Roamin
Yah, there definitely were domed piston to match that bathtub ... but whether you need higher compression is another question. There are pay off when you start to reduce the size of the chamber too much.
Old Dec 28, 2014 | 01:44 AM
  #38
D_gyver's Avatar
D_gyver
im not sure those are branch heads but they are like branch with the bathtub design.
I know of 4 guys building heads like this and there are probably more branch wasn't the first person to use this design. I personally don't like it because your limited to whatever pistons you can find getting the compression above 10:1 is hard to achieve.
most modified bathtub heads run between 72cc and 76cc with a w6 cam you need to shrink the combustion space at least another 12cc that's really hard to do without a domed piston.
if you can find a set of custom pistons for those heads the power and fuel mileage will be amazing but it wont be cheap.
Old Dec 28, 2014 | 02:40 PM
  #39
johnjzjz's Avatar
johnjzjz
you would only get flat top piston on my shop as a matter of fact if they made dish pistons you would get that - the shelf - is the total area covering the piston top not open to the cumbustion chamber, and what happens is at high engine speed when the rod and the piston streach out And they do - if you look at the combustion chamber hole you will see it is uneven wider at one end and that creates a head shake on the piston foward and backwards - this becomes a vibe in the bars that will numb your fingers < we did this all of it -
use a .020 base cometic tin gasket - use a .040 head est tin gasket - and a flat top piston and if you can measure the deck height you would want a negative .005 or .010 for the piston -- this set up will give you good street manners and long life < if non of that matters then drill holes for compression releases so when it hot and you shut it off and it post ignitions - well thats another post
Old Dec 28, 2014 | 07:46 PM
  #40
Jerrysounds
I hear you D_gyver. Hammer Performance makes pistons for the setup but I think Im going with the Cut "D" heads this season. Ill put a combo together using the bathtub heads for next winter. Something with the wood w9b or w9f cam (115 - 120 hp). I have all I need for this build so Im going with it. Thanks to all for the help. I'll post my dyno results in a week or so.
Big Money
Engine Mechanical Topics
11
Jan 9, 2016 12:10 PM
Jerrysounds
EVO
Dec 6, 2014 02:59 PM
machinehed
EVO
11
Jan 23, 2013 05:23 PM
01 chopper
EVO
14
Nov 21, 2012 05:30 AM
SBC427
Exhaust System Topics
15
Apr 22, 2010 07:24 AM
