Need help with upgrades
Old Dec 31, 2014 | 05:21 PM
BigBlock1969's Avatar
BigBlock1969
Default Need help with upgrades
OK guys and gals, I was a good newbie and searched the threads before I posted and could not find what I was looking for. I have added Rhinehart slipons to my 98 Ultra Classic and plan on adding a high flow air filter. I am by no means a "gearhead" but I am capable with tools and a service manual. My questions are 1. is a fuel management system absolutely necessary and 2. has anyone had any experience with the Cobra Fi2000 PowerPro. I have researched it and like the idea of an "auto tuner" but I can not find any one that has had any hands on experience with this system as most every one seems to use the PCIII. I just bought the bike last year and it is my first Harley. I love this bike but I just want to get a little more out of her. Only 39000 original miles according to the dealer. Thanks in advance.
Old Dec 31, 2014 | 05:56 PM
1997bagger's Avatar
1997bagger
You don't have O2 bungs to install sensors for a autotune and would need to weld some in.
Is it completely needed to put on a tuner with slips on and breather with your M&M, No
Will it make the engine run slightly better, slight power increase, Yes. The basic Cobra will do what you need and more simple than a PC3 for a DIY but PC3 is better for a dyno tune
Old Dec 31, 2014 | 08:10 PM
BigBlock1969
The Cobra Fi2000 PowerPro is available in a model that does not require o2 sensors which is why I was wondering if any one has used one. Most of my buddies are a little skeptical of a fuel manager that doesn't require o2 sensors.
Old Dec 31, 2014 | 09:47 PM
1997bagger's Avatar
1997bagger
A few members have come and gone that reported the Cobra does as advertised and honestly just guessing with it just like loading a canned map with a PC3. No way of knowing for sure unless you use a Wego system to read AFR's making changes as needed.
The largest portion of members here have already modded Evo's and found out that a prehistoric drip carb will out perform the M&M, made the switch and havn't looked back. My occupation is based on repairing EFI daily, a carb runs hands down better than the M&M.
Myself and others on here will give you advice or direction as nothing is wrong with M&M in a stock form but can get goofy when it starts to act up
Old Jan 1, 2015 | 11:19 AM
WP50's Avatar
WP50
What time I have hear, mostly reading 1997 bagger has said it right. Many when wanting more out of m&m bike have gone with a carb.
This was funny and a good many have said it to be true
"found out that a prehistoric drip carb will out perform the M&M, made the switch and havn't looked back. "
One of the reasons I bought the bike I did was that it had a carb.
Being an auto mechanic I will admit I dont want a carb on our vehicles, just on my bikes.
WP
Old Jan 1, 2015 | 04:37 PM
BigBlock1969
Thanks for the advice guys.
Old Jan 3, 2015 | 08:21 AM
grbrown's Avatar
grbrown
S&S does a tunable EFI replacement for MMI bikes, as an alternative to consider. Will a dyno do any good? The only bike I have used one on is my carbed Glide and the answer is emphatically yes! I have a modern exhaust with O2 sensor holes (normally blanked off), which my dyno man used while tuning.
Old Jan 7, 2015 | 01:20 PM
DeputyLoud's Avatar
DeputyLoud
I have the Cobra Fi2000 Power Pro on my metric cruiser. It's plug and play. Never had any issues with it whatsoever. It cycles and makes adjustments up to 80 times a sec. I spent the extra $ on it so I would never have to worry about any mapping. It should be able to handle and mods you may do in the future as well. Good luck!
wjl24
Nov 29, 2011 12:47 PM
gdhugh
Oct 6, 2011 12:20 PM
gdaustin
Feb 1, 2011 09:27 PM
craigffb
Jun 30, 2010 04:01 PM
buckjacklumas
Dec 6, 2009 08:43 AM
