EVO left me stranded today
Old Jan 17, 2015 | 06:39 PM
falconbrother's Avatar
falconbrother
Default EVO left me stranded today
1988, FLHTC.. I went out riding today and the bike was running maybe the best that it has ever run. After about an hour or so I stopped at a Subway and when I came back out the bike wouldn't fire at all. It turned over fine. I pulled the plugs and checked for spark and didnt see that there was any spark. I waited a while, tried my backup set of plugs, not so much as a cough trying to fire. I called my wife and to make a long story short got my trailer and loaded up the bike and took her home. I tried to start the bike when I got home and, just like before, it turned over great but, no start.
I went out to the garage a little bit ago to start pulling the tank and tried to start the bike and she fired right up like nobodies business. What could cause an intermediate spark situation? What would cause it to activate when the bike is shut down to then not have spark to restart? Do I need to replace my ignition system? I have a used ignition module I can install that I bought at a swap meet. I don't have a coil or the sensor so I'd need to order that. Any suggestions would be greatly appreciated.
My wife says I need a new(er) motorcycle. I say, no I just need to fix this one. She thinks I ought to get a Goldwing. I think I wouldn't like a Goldwing like I like my old Harley.
Old Jan 17, 2015 | 07:37 PM
johnjzjz's Avatar
johnjzjz
the trigger in the cone see if it looks as if its melting at the wire in location
Old Jan 17, 2015 | 08:09 PM
tmanbuckhunter's Avatar
tmanbuckhunter
I can't help you with your problem as I don't really know what's causing it, but I'm conflicted on getting rid of mine everyday... seems like each day there is a new problem, but then I fire it up and forget all about that non sense... hope you get it fixed soon.
Old Jan 17, 2015 | 08:22 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Old Jan 17, 2015 | 08:59 PM
JohnnyC's Avatar
JohnnyC
Odds are good it's the ignition module. This is exactly how they act when going bad, they become intermittent.
Been there, done that. I upgraded to a Crane Hi 4E. Had to upgrade wiring to the newer module style.
The timing sensor located in the nosecone more often fails completely. It's a magnetic reed switch. Newest version is a solid state module.
Substituting another module is the quickest way to trouble shoot the issue.
Old Jan 17, 2015 | 09:13 PM
Roadghost's Avatar
Roadghost
There's no point in guessing, you'll just end up swapping a lot of parts. You have to wait until you have the problem again and trace it back until you find where the current stops. It can't be that much of a problem, but you have to find it.
Old Jan 17, 2015 | 09:29 PM
Harleycruiser's Avatar
Harleycruiser
Originally Posted by falconbrother
1988, FLHTC.
Start with the basics, pull all of your connectors apart from the fuses to the handle bars, to the ignition, inspect them, clean them and use dielectric grease.
On older bikes this should be a regularly scheduled maintenance at least every two years or so depending how the bike is ridden.
Check for any loose wires, and if you did anything to the tank starting to take it off, check there.
Try wiggling wires to try to recreate the problem, if you can check the coil to see if you are getting current. It is hard to diagnose a problem when it cures itself randomly.
And forget the goldwing, they have no sole.
Old Jan 17, 2015 | 09:33 PM
Harleycruiser
Goodness this from a man with "your twin cam is ****" in his signature:-)
Old Jan 17, 2015 | 09:39 PM
Dr.Hess's Avatar
Dr.Hess
Only 3 parts to the ignition system, really: Coil, nose cone pickup or module. You have one of those bad. Nose cone, module, coil are in my opinion, the order most failures are seen in. The Book has diagnostic directions for the ignition system.
I think you should trade that thing in on a newer model. This time, make sure you get one that doesn't like Goldwings or other Honduhs.
Old Jan 17, 2015 | 09:43 PM
tmanbuckhunter
I grew up around die hard Harley riders who would bitch about how shitty their HD's were, and nothing has changed. Doesn't mean I'd rather be on a metric. The puddles of oil under mine are a right of passage.
OP, have you pulled your points cover off? A melted pickup will cause all sorts of funny problems.
