EVO left me stranded today
Old Jan 17, 2015 | 09:50 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by tmanbuckhunter
I grew up around die hard Harley riders who would bitch about how shitty their HD's were, and nothing has changed. Doesn't mean I'd rather be on a metric. The puddles of oil under mine are a right of passage.
OP, have you pulled your points cover off? A melted pickup will cause all sorts of funny problems.
On an EVO puddles of oil aren't a right of passage they are a sign of **** poor maintenance.
Old Jan 17, 2015 | 09:52 PM
tmanbuckhunter's Avatar
tmanbuckhunter
Bull ****. A leak on a 20 year old motorcycle is a sign of old age and rotted seals. Me and TJ replaced everything but one seal and that was the seal that was leaking... just the way it goes. Don't really care anymore... I only worry about the things that will leave me on the side of the road for now. It's getting torn down to the frame in another year or so anyways.
Old Jan 17, 2015 | 10:23 PM
Beemervet's Avatar
Beemervet
You can also heat the cone with a hair dryer or heat gun to try to duplicate the failure.
Old Jan 17, 2015 | 10:28 PM
tmanbuckhunter
I know my original one was melted all to ****... whatever filler/coating they put over the chip on the pick up is different now from the old brown stuff. It's black/clearish.
Old Jan 17, 2015 | 10:39 PM
MIKE93SVT's Avatar
MIKE93SVT
agreed. my evo doesn't leak, but used to. i have two shovels, and even they don't leak. certainly did when i bought them. after going through them, clean as a whistle. i build bikes as a hobby, buy them cheap, leaking, and neglected. sell them reliable and holding their own fluids. the only person to blame is the owner, or person turning the wrenches.
mike
Old Jan 18, 2015 | 12:09 AM
Hebrew Battle Rifle's Avatar
Hebrew Battle Rifle
The module on my 84 FXST died after 11 years. No warning at all. it just died. I replaced the electronic ignition with a Blue Streak points ignition and ran it for 9 years until I stopped riding. Converting to points took about an hour or so and I never once regretted the decision. I am in the process of brining my 84 FXST back to life and when it fires up, it will have Blue Streak point in the cone.
Old Jan 18, 2015 | 05:21 AM
Schex's Avatar
Schex
I hear that, I'm switching back to total loss oil system too.
Old Jan 18, 2015 | 05:25 AM
Schex's Avatar
Schex
Ah ha, so that's how you keep the mud from off-roading from sticking.
Old Jan 18, 2015 | 05:49 AM
br549A1's Avatar
br549A1
This is what you need to do. Get it nice and hot and see if it will start. Or get some of that compressed air in a can and wait until it won't start and spray it with the air to cool it and see if it will start.
Old Jan 18, 2015 | 07:06 AM
falconbrother's Avatar
falconbrother
So, I guess I need to drill the rivets on the nose cone cover and look at the sensor? The engine is a HD factory refurbish that was done about 35,000 miles ago and in the winter of 04-05. The module and the coil are the original 1988 version. I don't know if HD replaces the sensor behind the nose cone on a refurb or not. Anyway, it's an issue that occurs when the bike is at operating temperature and it's getting worse. I thought it was the carb and, there may have been an issue there because it does start super easy and idle better since I upped the idle jet size to a .31 on the S&S. Clearly I had two issues that kept stranding me. Before I would eventually get the bike to start. Now, it wont start again for hours. The bike has to be completely cold to start. That kinda makes me think it's the sensor in the nose cone sine that would be that last part to cool down. I really want to stay as close to stock on the ignition as I can. Are stock-ish sensors still available? I am ordering a coil today and I already have a module.
