Adding kickstart to an Evo.
Old Feb 9, 2015 | 06:04 PM
Tee&Vee's Avatar
Tee&Vee
Nice sprotor, Tom. With most braking done with the front brakes, that being said, how do you like its performance?
Old Feb 10, 2015 | 09:25 AM
musicnbikes's Avatar
musicnbikes
Originally Posted by Tom84FXST
And the fun part is, virtually no exhaust manufacturer claims that their exhaust will fit an 84-85...they all say 86-99...I have run several exhaust that said they only fit 86-99.
Which exhausts are on your bikes, if they are yours?
Old Feb 10, 2015 | 04:13 PM
Tom84FXST's Avatar
Tom84FXST
It is the same bike...first pic is santee "venom" that they made for big bear choppers...second pic is a samson 2 into 1 that they no longer make.
Old Feb 10, 2015 | 10:59 PM
Bikerscum's Avatar
Bikerscum
You can do it from a kit, at least I did way back when. I assume they're still available. You don't have to change the mainshaft, there is an extension that threads onto the end of it. You'll need to change the side door for the one in the kit, but with a special puller you can do it while it's still on the bike. You can do the whole job in a weekend.
My staggered duals that I had before the mod fit fine after, I did have to elongate the mounting holes a touch. The one downside to the whole thing is that as someone mentioned, it sticks out a bit. Not a problem when riding & feet up but you have to straddle it at a stop.
I say go for it.
Old Feb 11, 2015 | 09:33 AM
corliss@bakerdrivetrain.com's Avatar
I see Kurt still doesn't have his new website up yet but here is his facebook page. You need pipes to work with a kicker here's your guy.
https://www.facebook.com/pages/Kleiv...12876578750993
Old Feb 11, 2015 | 07:36 PM
Thingfish's Avatar
Thingfish
Is a compression release needed? Can a stock ignition work on a '92 or would i need something like a Dyna S?
Old Feb 12, 2015 | 04:51 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I need more information to answer your questions.
What size pistons do you have?
If stock then you don't need compression releases.
Can a stock ignition work on what?
Do you have electronic ignition?
Old Feb 18, 2015 | 09:05 PM
Scootertrash60's Avatar
Scootertrash60
Originally Posted by glidein wide
So true, probably because some 84's had shovels and some had new evo. Which of course wouldn't fit both but when you know what you got you know what should work. It's been fun learning what fits an 85-86wide glide, kinda like a mutt but I like it.
Ha!
Same with my 85 Low Rider. I'll never sell it tho!
bluharley
EVO
Jul 12, 2014 04:22 PM
JimA
Mar 11, 2012 07:38 PM
nh-dwg
EVO
Jan 19, 2012 04:31 PM
chevypilot
Mar 31, 2009 09:23 AM
rotorhdh2
Feb 5, 2007 02:01 PM
