96 FXDWG 100000 klms
Old Feb 16, 2015 | 12:57 PM
Arend's Avatar
Arend
3rd Gear
Default 96 FXDWG 100000 klms
My dyna has been sitting for the last 3 years because it doesn't run rite any more.....for you guys that want to read..allow me to give you the history on this bike
I am the original owner.
It has stage one done to it thats all.. and i raised the bars.
Three years ago it started to misfire and backfire severely out of the top muffler...i mean there was orange flame.
I decide to get $10 dollar maintenance manual off internet...that was probably a mistake...I have now ordered a real harley maintenance manual for 96 FXDWG..that was 3 weeks ago and I still dont have it.
I decide to drain the tank..take tank off..and lower the rear engine mount so as take off the rear head assembly.
I decide to give it a new ring job and have the heads redone at a harley shop and i re-install every thing...I also had a look at valve lifters...they look brand new.
I also get new harley battery, spark plugs, plug wires and a new coil..all stock stuff straight from harley.
It will start but misses on rear cylinder on initial start up and then clears up...but here is what it does.
It appears to run with choke fully on for several minutes ..fair amount of black smoke..but as i slowly push choke in it runs but gradually seems to choke itself....and then there is blue smoke coming out that top muffler after engine has warmed up significantly.
Would anyone with lots of EVO engine experience have any ideas as to what i may have done wrong.....thanks...my name is Arend
Old Feb 16, 2015 | 01:49 PM
glidein wide's Avatar
glidein wide
How was the intake and carb when you broke it down,seal for the rear jug and such . Did you look at cam lobes at all or inspect push rods?
Old Feb 16, 2015 | 02:00 PM
flhchaz's Avatar
flhchaz
I similar symptoms on my 97 flht. The culprit was a leaking intake gasket (quite common), I have also has the carb to intake donut gasket go bad that will also cause hard missing.
Old Feb 16, 2015 | 02:11 PM
glidein wide
Upon reassembling, did you tighten intake a little at a time , front/ rear . You can't tighten one side then the other.
Old Feb 16, 2015 | 04:59 PM
Arend's Avatar
Arend
3rd Gear
ya thx for getting back....yes the carb connections I did the front then back equally and I feel that's ok
Old Feb 16, 2015 | 05:03 PM
Arend's Avatar
Arend
3rd Gear
yes I looked at that stuff and I was surprized at how good it looked...I mean no wear what so ever
Old Feb 16, 2015 | 05:16 PM
flhchaz's Avatar
flhchaz
Did you pull the pushrods? if so, are you certain that they went back to the correct place?
Old Feb 16, 2015 | 10:03 PM
D_gyver's Avatar
D_gyver
blue smoke is oil your oil ring is failing or valve seals
Old Feb 18, 2015 | 10:41 PM
Spanners39's Avatar
Spanners39
Did you have the bores honed by someone who knows how to use torque plates?
Old Feb 18, 2015 | 11:21 PM
Arend's Avatar
Arend
3rd Gear
Had all that work done by Harley shop
freddy2081
Exhaust System Topics
Jun 13, 2013 08:12 AM
HB
Feb 19, 2013 09:00 PM
DynaFX96
Oct 31, 2012 10:42 AM
buzzardgame
Ironhead
Mar 11, 2008 08:31 AM
Cageless
Mar 15, 2006 10:59 AM
