Is a little whine while engine braking normal?
I recently cleaned my carb, and I'm sure it was pulled and replaced when my mechanic did the cam bearing, any chance the shudder is just a stumble from lean condition as the RPM's decend? (Manifold vacuum leak or something).
If so I would bet it is something he did.
As for the clutch in / out, I just want to clarify that the whine I hear is when I release the clutch after downshifting (shift down, slowly let clutch out, compression braking decelerates the bike).
It doesn't make any noise when it's in. I'm triple checking the cam chain but it may just be the normal sound of the clutch going from sitting still (idle with the clutch in) fighting the oil to spin up when the clutch is released (my Kawasaki makes a very similar noise, and I watched several videos of different bikes engine braking and they all have at least a little bit of a "whine" as the motor spins to catch up with the rear tire).
I'm also going to check the compensator nut while I'm in there. Any recommendations for primary lubricant when I button it back up? (Can of worms... I know).
I'm thinking my "shudder" is a lean condition stumble at this point, probably from an intake leak. I'm going to use the carb cleaner trick and verify that tonight. It only seems to do it once the bike is up to operating temp.
Thanks SO much to everyone who's replied so far. I'll update when I've got the primary buttoned back up (or if I find anything telling inside).
Edit: I should also note that in the picture, the front motor mount being gooey is my fault, it gets that way when I change the oil filter, I hadn't cleaned it up yet.
Something about the idea of ATF in the primary has always seemed like a bad idea, but then again I'm neither a mechanic nor engineer. I'm pretty sure what I had in there was correct per owners manual but it definitely wasn't "primary" anything, just the correct weight. I'm rethinking that going forward because I'm sure there's a lot more to oil than just the right weight.
Thanks again!
