Cylinder Stud Torque
Old Mar 14, 2015 | 12:40 PM
br549A1's Avatar
br549A1
Default Cylinder Stud Torque
Found this today and after reading a few threads it's never been answered. Here's the correct answer. 10 ft pounds
Old Mar 14, 2015 | 03:03 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Hell I didn't know anybody was asking!!!
Old Mar 14, 2015 | 04:22 PM
br549A1's Avatar
br549A1
Well I looked today and searched on here. It was asked many times but no one ever answered. I figured it would help someone in the future.
Old Mar 14, 2015 | 04:45 PM
texashillcountry
Dirt don't hurt
FWIW engine studs are installed to a specific height.
5.67in to 5.77in.
I'm fairly certain that the 10 lbs torque setting you found applies to the case bolts.
Old Mar 14, 2015 | 05:10 PM
br549A1's Avatar
br549A1
Originally Posted by texashillcountry
FWIW engine studs are installed to a specific height. 5.67in to 5.77in. I'm fairly certain that the 10 lbs torque setting you found applies to the case bolts.
Nope. It's the cylinder studs which is why I posted it and the image from the manual. Maybe yours are the older style without a shoulder. Mine have a shoulder and a recess where the shoulder makes contact with the case.
Old Mar 14, 2015 | 05:49 PM
texashillcountry
Dirt don't hurt
Just out of curiosity what manual is that in?
Old Mar 14, 2015 | 05:57 PM
br549A1's Avatar
br549A1
FSM. 1997/1998 Dyna
Old Mar 14, 2015 | 06:15 PM
texashillcountry
Dirt don't hurt
FSM. 1997/1998 Dyna
I find it interesting that 2 different manuals talking about the same motor have different information.
Weird huh?
Old Mar 15, 2015 | 05:19 AM
br549A1's Avatar
br549A1
I find it interesting that 2 different manuals talking about the same motor have different information. Weird huh?
What year is your manual? If yours had the shoulder up from the factory then it's different. At some point they switched to shoulders and changed the instructions to shoulder down
Old Mar 15, 2015 | 07:19 AM
glidein wide's Avatar
glidein wide
Did they change to shoulder bolts for perfect jug alignment at some point? If so the gaskets must have changed also. And does that mean the bottom of the jugs would be opened to accept the shoulder, making all years NOT interchangeable?
