Oil, Syn or Dino?
Old Mar 25, 2015 | 05:46 AM
QC's Avatar
QC
Old Mar 25, 2015 | 02:24 PM
Ape_Hanger's Avatar
Ape_Hanger
I ran synthetic in my Evo once. Never again. The motor was noisy and it weeped like crazy, everywhere. Flushed that crap out and went back to the Valvoline VR1 50W and all the weepiness was gone.
Old Mar 25, 2015 | 03:12 PM
touchdown's Avatar
touchdown
SYs oils are very good but in older engines will fine there way out leaks. I would use a name brand Motorcycle oil and change it @3000 to 3500 miles
Old Mar 25, 2015 | 03:17 PM
johnod's Avatar
johnod
Ok, then do air cooled V twins require anything different in conventional oil than say a water cooled 4cyl?
I've been using Castrol MC oil in them any reason to change for the HD?
Old Mar 25, 2015 | 03:27 PM
touchdown's Avatar
touchdown
use motorcycle oil only its for air cooled engines
Old Mar 25, 2015 | 03:30 PM
tmanbuckhunter's Avatar
tmanbuckhunter
You don't need motorcycle only oil for a Harley Davidson. They don't use a shared sump and will benefit from a quality car oil with friction modifiers.
Old Mar 25, 2015 | 03:51 PM
Spanners39's Avatar
Spanners39
They need a high zinc content, much like a diesel truck. Spectro, H-D and Mobil are three brands that are very good.
Old Mar 25, 2015 | 06:14 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I understand the Valvoline VR1 (pick your oil weight) also is high in zinc.
Old Mar 25, 2015 | 06:48 PM
Ape_Hanger's Avatar
Ape_Hanger
Correct. I run the 50w. The gentleman that recommended it to me had 150,000 miles on his 95 Dyna last time I spoke with him, and he hadn't been into the motor yet.
Old Mar 26, 2015 | 08:42 AM
IBDAGRIZ's Avatar
IBDAGRIZ
I run 20-50 Synthetic in my S&S motors as that is what they originally had in the manual to run in it. Never had a leak issue. Run the same in the 96" motor I built and no leaks on it either.
Guess I am luckier than the others here..
Synthetic 75-140 in the 6 speed tranny and Type "F" ATF in her primary.
I did use the Valvoline Racing oil in dino to break the 96" in as I do any motor I build.
Griz
