Oil, Syn or Dino?
Old Mar 24, 2015 | 10:16 PM
johnod's Avatar
johnod
Default Oil, Syn or Dino?
Are people running syn oil in their Evos, motors, trans, primary?
I've always used dino in all my bikes, and for the past couple of years Castrol.
But I'm considering changing for the 2 HD motors, any opinions or recommendations?
I did check the oil forum first, but didn't see anything Evo specific, so I'm asking here.
Thanks
Old Mar 24, 2015 | 10:56 PM
Spanners39's Avatar
Spanners39
Oil threads are forbidden on here because people cannot understand how anyone could use a different brand to them BUT generally speaking you don't use Synth in an Evo unless you like oil leaks....bloody stuff escapes...
Old Mar 24, 2015 | 11:00 PM
johnod's Avatar
johnod
Ok thanks, didn't know about the verboten bit.
Old Mar 24, 2015 | 11:42 PM
Dave's 1stHog's Avatar
Dave's 1stHog
Johnod, don't worry about the previous comment, if you have a question, any question, feel free to post it here. Now, as far as the oil questions go, you are going to get the majority of responses being a smart *** or just plain rude; that's because there are a ton of threads about that subject and it just turns into a typing war when tempers flair over which oil is better! Your question is valid so I hope someone can give you honest feedback. Good luck in your quest for knowledge.
Old Mar 25, 2015 | 12:32 AM
tmanbuckhunter's Avatar
tmanbuckhunter
Hi Dave, it appears you're lost. Let me help you get back to where you came from. Twinkie land is right this way https://www.hdforums.com/forum/softail-models-7/
Don't use synthetic in your Evo... there is no need to, and if you have any leaks that you don't know about, you'll know about it with synthetic. In my experience, synthetic works much better in water cooled engines. A quality 20w-50 or straight 50w dino is all you need for your evo.
Old Mar 25, 2015 | 12:43 AM
Hackd's Avatar
Hackd
Harley dino oil in the V2. Mobil 1 gear lube in the trans. Whatever crap The MoCo sells for the primary...
Which reminds me, I need to do an oil change....
Old Mar 25, 2015 | 01:10 AM
0maha's Avatar
0maha
Follow the factory specs, change it per the factory interval, and find something else to worry about.
Old Mar 25, 2015 | 02:34 AM
Spanners39's Avatar
Spanners39
I hope someone can give you honest feedback. .
I did.....
Old Mar 25, 2015 | 02:47 AM
Beemervet's Avatar
Beemervet
Blowtorch!
Old Mar 25, 2015 | 05:09 AM
grbrown's Avatar
grbrown
John, as mentioned oil is a subject that raises blood pressures, in fact across the whole of HDF, not just in here! Our Evos were made before synthetic oils became commonly available and they are best left on the shelf, as already suggested. There are more brands available than anyone can count, many unsuitable, so it is best to tread your own path. The oils from your local friendly dealer are most satisfactory!
