Brake pedal
Old Apr 13, 2015 | 07:26 PM
RANGER73's Avatar
RANGER73
Either replace the foot pegs, rotate the foot pegs or get some peg offsets.
Old Apr 13, 2015 | 08:44 PM
br549A1's Avatar
br549A1
Was looking at offsets today wasn't sure if they would work right. I have two sets of pegs now, maybe I can just bend the pedal left a little. Just seems like there's no room and there should be.
Old Apr 13, 2015 | 11:17 PM
Son of PMS's Avatar
Son of PMS
I also have Kury forwards and have considered bending - straightening the brake arm to move the pedal left and out of the way of my size 12 foot. It occurred to me that bending the arm might break the chrome loose so I didn't try it.
I did flip the pedal over, so the square end is to the right. Had to drill a new hole for the mounting screw. Gave me maybe 1/2" to 3/4" more clearance. Filled the old hole with RTV so it wouldn't rust. It's better, not perfect. I can mostly keep my foot square and straight on the peg.
I'll try to post a pic tomorrow.
Old Apr 14, 2015 | 05:13 AM
br549A1's Avatar
br549A1
Originally Posted by Son of PMS
I also have Kury forwards and have considered bending - straightening the brake arm to move the pedal left and out of the way of my size 12 foot. It occurred to me that bending the arm might break the chrome loose so I didn't try it. I did flip the pedal over, so the square end is to the right. Had to drill a new hole for the mounting screw. Gave me maybe 1/2" to 3/4" more clearance. Filled the old hole with RTV so it wouldn't rust. It's better, not perfect. I can mostly keep my foot square and straight on the peg. I'll try to post a pic tomorrow.
Thanks a picture will help. Glad I'm not the only one with the issue. I'm thinking of trying those offsets, will probably make the pegs more like floor boards a little lower and closer, but I hate dropping $50 on something that might not even work
Old Apr 14, 2015 | 05:41 AM
D_gyver's Avatar
D_gyver
from what i can tell those are not front pegs those are mini floors for a passenger there to short your pegs should stick out about 3 inches further than the pedal.
that setup look dangerous
Old Apr 14, 2015 | 05:50 AM
br549A1's Avatar
br549A1
Originally Posted by D_gyver
from what i can tell those are not front pegs those are mini floors for a passenger there to short your pegs should stick out about 3 inches further than the pedal. that setup look dangerous
Feels dangerous too. Here's a link. It said could be used for either. I have he ISO pegs with stirrups I just get cramps was trying to get a larger foot platform I can move around on. The kuryakn 4392 might work I can slide those but again, $80 and they might not work. They also don't have horizontal ridges like these for the boot to grab. I have to unload the HD mounts now.
http://www.harley-davidson.com/store/mini-footboard-kit
Old Apr 14, 2015 | 03:22 PM
Son of PMS's Avatar
Son of PMS
Old Apr 14, 2015 | 05:29 PM
falconbrother's Avatar
falconbrother
On the brake light switch.. Get the HD switch. Yes, you can screw a generic switch in there from AutoZone but, they suck. The HD switch is inexpensive and last a lot longer.
Old Apr 14, 2015 | 05:44 PM
Harleycruiser's Avatar
Harleycruiser
Anytime you open up the brake line you are going to let fluid out and air in, and there is going to be air in the new switch. The back brake will not blead itself like the front because there are areas that trap the air so you need to be prepared to blead the system after you are done.
Also that looks like an extended pedal to me.
Old Apr 14, 2015 | 08:01 PM
Pothole914's Avatar
Pothole914
What he said. Anytime you open up a hydraulic system, YOU WILL GET AIR. I don't care what anyone tells you. Bleed the system after replacing the switch and be done with it.
