3rd 4th chattering
Old Apr 15, 2015 | 09:15 AM
corliss@bakerdrivetrain.com's Avatar
Were both the spacers installed on the mainshaft and counter shaft before they were pressed into the bearing door?
Old Apr 15, 2015 | 09:40 AM
RidemyEVO's Avatar
RidemyEVO
Yes they were. When I rebuilt this tranny a few years back it had all new spacers bearings etc. I took this tranny out and put a new tranny in its own gearcase. This tranny I pulled the casette out of its case to get the case welded and the mainshaft and countershaft were never pulled from the bearing door. I simply reinstalled the casette back into the repaired gearcase and reinstalled the entire unit back into the bike. When I took this tranny out of the bike I had no issues with it. I'm starting to think it was a bad thing using the shifter forks in this tranny after they had run in the other tranny for so long. I gave them a good look and there is no obvious bend on the forks but when I check them with a ruler they appear not to be perfectly flat but not being someone who does line work everyday I can't say I have the trained eye to see a bent fork when I see one.
Old Apr 15, 2015 | 03:07 PM
Here is something to check concerning the forks, with the top cover off put the bike in 3rd, grab each fork and give it a wiggle it should have a little play
if it doesn't then that fork may be bent and binding. Do the same thing in 4th.
Old Apr 15, 2015 | 03:17 PM
Something else, in a couple of your pics, the 4th main looks really discolored as if it got hot. The teeth don't look very sharp on that gear either, if a single tooth gets distorted or you can grab a ridge or a valley in a single tooth with your finger nail it will make noise.
EDIT: I mean the 5th main.
Old Apr 15, 2015 | 04:40 PM
RidemyEVO's Avatar
RidemyEVO
Thanks Mark I went through all the motions you described.
Found the culprit when I was rolling the tranny around after putting in 3rd then forth and just happened to spot it.
Broken tooth was sitting in bottom of case
Old Apr 15, 2015 | 05:05 PM
D_gyver's Avatar
D_gyver
glad you found it
Old Apr 15, 2015 | 08:18 PM
glidein wide's Avatar
glidein wide
That sucks, but what caused it .?
Old Apr 15, 2015 | 10:04 PM
RidemyEVO's Avatar
RidemyEVO
Pretty sure what caused it was when I locked the tranny gears while installing the tranny and when I locked the gears to torque down the primary side the gears may not have been lined up properly, I do recall hearing a ping while torquing but wasn't sure what it was.
Old Apr 16, 2015 | 08:17 AM
That'll do it.
86glider
Aug 31, 2018 01:38 PM
kcollins
May 16, 2017 07:03 PM
Ccr71
Apr 11, 2017 04:29 PM
oldcorps116
EVO
May 19, 2013 02:10 PM
lou1
May 5, 2008 07:50 AM
