Brake help needed
Old Apr 18, 2015 | 04:13 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by hubcap
This is what I'm thinking... Not sure why the pics got turned sideways but they are taken standing in front of the bike looking down. The first pic is the right side, you can actually see the pad, the other pic no pad. BraPads are new.
All I can think of is take it apart again and look carefully at everything.
It doesn't look like it but did you put some kind of spacer behind the rotor?
Old Apr 18, 2015 | 04:31 PM
hubcap's Avatar
hubcap
Originally Posted by Stiggy
Wheel put in correctly, with the valve stem facing the right side of the bike?
Yes, wheel is in correctly.
Old Apr 18, 2015 | 04:52 PM
Stiggy's Avatar
Stiggy
There are spacers often put under the calipers right from the factory sometimes. They are there to center the calipers right over the center of the rotors. Worst case you may have to resort to such a measure. (The line that splits the caliper, directly over the center of the rotor.)
Old Apr 18, 2015 | 04:53 PM
Harleycruiser's Avatar
Harleycruiser
Did you have the calipers off?
Old Apr 18, 2015 | 05:07 PM
texashillcountry
Dirt don't hurt
Got a source for the spacers?
Old Apr 18, 2015 | 05:35 PM
Stiggy's Avatar
Stiggy
I had some lying around from some aftermarket brake kits and supplemented those with washers that I picked up at Lowes. They had several different thicknesses in their inventory.
Old Apr 18, 2015 | 07:18 PM
texashillcountry
Dirt don't hurt
I went looking in the Drag book and found some shims for Performance Machine calipers.
I'm guessing that is what you are talking about.
Old Apr 18, 2015 | 07:34 PM
hubcap's Avatar
hubcap
No spacers behind the rotor. I just went out in the garage and took it apart again. Put a washer between the original spacer and the fork and it fixed it...caliper is off the rotor. I appreciate all the help, I'm kinda new to the Harley stuff. Is there a spacer inside the wheel between the bearings?
Old Apr 18, 2015 | 09:56 PM
texashillcountry
Dirt don't hurt
I'm glad you got it fixed but I wonder what changed that required an extra spacer to fix your problem.
Yes there is but you don't mess with it to sort your brakes out.
It is there to maintain a certain distance between your wheel bearings and your races.
Actually there is a better way to say what it does but I ain't good enough with words to explain it.
Old Apr 18, 2015 | 10:05 PM
ajayrk's Avatar
ajayrk
This is an '85 front wheel.
It only has one spacer.
Spacers in the seals: Left spacer 43342-83, right spacer 40910-84A.
Did the spacers fall out of the wheel?
Is there a spacer inside the wheel between the bearings? Yes and it has thin shims to set the bearing end play.
