I did a brake upgrade (pics)
Old Apr 23, 2015 | 08:23 PM
misfitJason's Avatar
misfitJason
I had already upgraded my rear brake on the softail to a pm 4 piston. Now it was time for he front. When I did a front brake upgrade on my twincam dyna to a radial mount I saved the stock 4 piston caliper. I came across an adapter bracket by bikers choice that came with all the hardware and shims for about 45 bucks on Amazon. It adapts 00-newer calipers to 84-99 legs. I will say that the kit is nice and all chrome. I am not of fan of chrome because it rusts to **** here in Florida so I will probably change everything out to stainless. Anyway, I also had a master cylinder and clutch perch from a twincam to do a nice conversion of the handlebar controls Now my clutch pull is nicer with the open belt drive clutch being so stiff because of the bigger flatter levers. Here are some pictures. You need a new line and some takeoff stuff because this system uses dot 4 it stops legit now. And with a passenger
Here's a pic of the conversion I did on my dyna. This **** works well Enjoy
Old Apr 23, 2015 | 09:27 PM
Hopper's Avatar
Hopper
Neat.
Did you fab up the adaptor for the radial mount caliper or are they available somewhere?
98hotrodfatboy's Avatar
98hotrodfatboy
very nice. I like the rim and the way the rotor mounts to it. very nice.... are you gonna do the rear? I'm still waiting for my new rims and matching floating rotors...
Old Apr 23, 2015 | 10:07 PM
misfitJason
Originally Posted by Hopper
Neat. Did you fab up the adaptor for the radial mount caliper or are they available somewhere?
The one for the radio caliper is a speed merchant part. It's for 11.5 inch rotors but I had an 11.8 inch stock so I had to have some spacers machined. That bracket was 140 and the brake caliper was 30 bucks
Old Apr 23, 2015 | 11:02 PM
Beemervet's Avatar
Beemervet
Nice job Jason. I did the same on my '98 RG. It's amazing how much difference there is between the stock 2 pot calipers and the 4 pot. First time out, three miles from home on the interstate I needed to slow down fast and briefly locked up the front tire. YEE HAW!
Brembos next........
Old Apr 24, 2015 | 06:47 AM
glidein wide's Avatar
glidein wide
That's Purdy, cap the axle and slow that rust on your spokes before they weaken. Lots of moisture in the"sunshine state" ...good job....
CamelRider
Sep 27, 2018 03:39 PM
langwilliams
EVO
May 7, 2016 06:56 AM
Kevin714
Apr 14, 2014 05:20 PM
last saint
Jan 3, 2011 08:03 PM
johnzlee
Jan 14, 2008 06:59 PM
