Warping derby covers
Old May 6, 2015 | 10:02 PM
  #31
glidein wide's Avatar
glidein wide
Originally Posted by bluharley
You have to tighten the screws as tight as you can using a driver, you don't want them vibrating loose, you see. Then, after a couple years, you'll have about a 1-2mm high point between each screw. Over the next couple years, the gaps will grow, and even using Permatex will not stop the leaking. You've been doing it wrong. Just follow my directions, and you'll have a nice leaker.
Old May 7, 2015 | 08:30 AM
  #32
Heritage98's Avatar
Heritage98
I too have warped them but now when I change the primary I wrap the cover in a towel put it on a piece of plate steel and use a rubber mallet on each side of the holes and no more leak.
Old May 7, 2015 | 02:11 PM
  #33
bluharley's Avatar
bluharley
After a ride today, no leaks! Been a long time I took Heritage98's tip, and flattened out the old one with a rubber mallet, it didn't take much. I'll hold on to it for when this cheap one warps! The old flames have lost their luster.
HeliRider
Feb 17, 2010 03:20 PM
Pugz2727
Apr 2, 2008 02:10 PM
dawn
Oct 2, 2007 10:49 PM
Grendel UK
General Topics/Tech Tips
Sep 30, 2006 07:50 AM
LOWRIDER95
Apr 12, 2006 07:45 PM
