The neck bearings are adjusted, a tad on the tight side. I did have a slow speed decel wobble but that's gone now with the neck adjusted properly. I am getting a clunk on the rebound after a hard front breaking. Like its topping out or something when i let off the front break and the forks are extending back to normal posistion... I have changed the fork oil with 11.5 ounces 15 weight. the bike is a 1999 FLSTC do you think the oil is to thick or not enough to cause that? There is only 7,500 original miles on it
Had that bike been sitting for awhile before you got it? If it is air shock check if you have any pressure. You may just need to pull it apart and clean it out, baffles may be shot.
Same front end as on my98 fatboy. They use the fall away adjustment for the triple tree bearings. Not absolutly sure but I think 11 oz is about the most you want to go. And by design these front ends clunk. Nature of the best....
Get rid of the "type E" fork oil. Use the "performance heavy" SE stuff. I do, and the front end is much better behaved.
Other than that, make sure you don't have a broken lower fork leg pinch bolt. That's happened to me twice, always on the left fork leg. Also, how's your wheel bearing end play? Either of these things can cause a "clunk" noise.
For a nominal investment (around a "C" note), Progressive Suspension fork springs will make a huge difference in ride, handling and comfort. Worth considering once you're sure everything else is up to par.
Its not the pinch bolts as i losened/tightened them to do the neck bearings/fall away.. I do have the manual, and the fall away is good now, it was a little loose so i did have a slow speed wobble when i let go of the bars.. thats corrected now.. The manual did say 11.5 oz's I'll check the wheel bearings but im sure its in the forks. Thanks for your answers. Progressive springs might be the answer
you had it to tight at first and now its a tad bit loose - you need to move it just a slight bit tighter as it now has up and down movement the bearings are knocking on sharp bumps and or on the brakes hard
Uncle G, I used to have a 94 Special also. Sadly I lost it in a house fire in 08
Sad to hear that. I came near to losing mine in a traffic accident last summer. Fortunately, there was no frame damage, and I was able to source the needed parts to repair it.
