oil light
Old Apr 30, 2007 | 03:43 PM
ThePunster's Avatar
ThePunster
Default oil light
I changed my oil before te winter, and just rolled her out to fire her up Saturday. The oil looks clean and at the right level but the oil light seems to be dimly lit. Not full bright like it is when you first turn the key, before you hit the ignition, but not off either. Is this possible or am I imagining things? What could cause this? I thought the light would be on or off.
Thanks - 1998 FLHTCUI
Old May 1, 2007 | 12:15 PM
ThePunster's Avatar
ThePunster
Default RE: oil light
Does anybody have an idea if the light can be only partially on and why that would be?
Old May 1, 2007 | 12:45 PM
Jeff_96RK's Avatar
Jeff_96RK
I'm no expert, but sounds like a bad ground or faulty or loose light or bad connection.
Old May 1, 2007 | 01:28 PM
nfe's Avatar
nfe
Scares me anytime that light is on.. Even when the key is just turned... (Just cuz)
Old May 2, 2007 | 03:29 PM
scott4911's Avatar
scott4911
Mine looks like the oil light is on if the bike is in neutral. The neutral light is bright and shines a little bit over onto the oil light. Mine's a 94 Softail, dash. Your's might be digital being a 98??
Mine goes off when I put it in gear...
Old May 5, 2007 | 06:02 PM
dog155's Avatar
dog155
Sounds like a bad connection to me,check the switch.
wengerda
Jun 21, 2018 11:30 AM
Klarick
Oil Archive (no new posts)
May 8, 2014 07:47 PM
HOTROD TODD
May 20, 2007 10:44 PM
ThePunster
Apr 30, 2007 06:25 PM
MDMYMD
Nov 2, 2006 09:47 PM
