Replace 1985 Fuel Tank
Old Jul 22, 2015 | 09:30 AM
Flanman55's Avatar
Flanman55
Default Replace 1985 Fuel Tank
Looking for a replacement for the stock 1985 FLHTC gas tank. Don't want a stretched look just a more rounder look. Any ideas and thoughts you guy have would be great.
Thanks
Old Jul 22, 2015 | 09:37 AM
Racepres's Avatar
Racepres
Look around [especially in the Shovelhead section] for the "T" conversion to Road King type...
Not that Hard really...Look pretty good too, since the RK is nothing but a redo of the original FLHS!!
Old Jul 22, 2015 | 09:47 AM
grbrown's Avatar
grbrown
The tank used on the following models, including my 1990 FLHS, is more rounded than the earlier flat-sided style and should be the easiest to adapt. If you're a glutten for punishment you could always try one of the latest 6 gallon tanks, which can be persuaded to fit, as long as you don't have the c/v type carb!
Old Jul 22, 2015 | 09:50 AM
Flanman55's Avatar
Flanman55
Well the 6 gallon is out because I hate punishment and I am putting a CV carb on. But i will be looking for a early 90's style tank...
Old Jul 22, 2015 | 12:54 PM
Prot's Avatar
Prot
I just looked at JP Cycles and there are many to choose from for your bike.
Old Jul 22, 2015 | 05:16 PM
Tom84FXST's Avatar
Tom84FXST
You can put just about any newer touring tank on there without much trouble. The front mount has not moved since the shovel days...I have a newer street glide tank on my 83...had to drill one hole and use a carb petcock adapter,since it was a fuel injected tank...I welded a nut to the frame for the rear mount...but you could use a rivet-nut.
Old Jul 23, 2015 | 04:01 PM
Flanman55's Avatar
Flanman55
Thats exactly what I am looking for... Thanks
What year of tank is that?
BWann495909
Jan 18, 2015 05:46 AM
hopatro@gmail.com
Dec 31, 2011 11:33 AM
madcritter
Carburetor Related
Aug 13, 2009 10:59 PM
tcs59
Jul 2, 2009 09:57 PM
bv
Exhaust System Topics
11
Mar 3, 2008 12:59 AM
