Thanks for the ideas. I'm definitely going to go the easier route before going to the clutch hub. I'll keep you all updated
Thats a good way to approach what your going after. I'm the guy THC mentioned with the clutch hub. KP went through more than I did trying to get the vib to a point he could live with. I was able to find several EVO's to ride between friends, a couple indy,s I know well and test ride a few while I was considering clunking the one I have off a bridge. All of them had some level of vib around 1800-2000 rpm. Mine just happened to be bad enough to blurrr the gauges from 1600- around 2400 rpm. And forget using the HWY pegs above 3000 rpm in 4th 0r 5th gear.
Lots of things to ck before ya go after a clutch hub unless you happen to be in the there. From what i have read and talked about my situation was an extreme rarity. I'm just thankful that that I got pointed in the right direction and was able to find someting I could point a finger at and know it wasn't right
My clutch hub had a spun bearing. It was pretty bad. Wasn't it though. I did the inner primary bearing too. Didn't matter. I found lots of bad things but nothing was it. Even leaking valves and severely worn cam and lifters.
