Excessive vibration
Old Aug 2, 2015 | 09:57 PM
Jchaiyo's Avatar
Jchaiyo
Default Excessive vibration
Ok so 1992 fatboy.
Had the bike since 08.
So Friday I decided to go to a strip club on the bike and I couldn't get it into 3rd gear or higher.
Today I adjusted the shift engagement screw. Grinded down a 11/16 box wrench and adjusted the shift where I can get it to go in all gears. Test rode today so far so good.
I have a problem. My teeth vibrate so much I worry they are going to fall out. My body shakes for 20min after I get off the bike. Of course evo are rigid mounted and if it didn't shake raddle and roll it wouldn't be a harley, but has anyone experienced this and what are the remedies?
Old Aug 3, 2015 | 07:29 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
One guy I know found that the gear on the clutch hub was loose and it was causing him excessive vibration.
You might also look at replacing the rubber isolators under the risers.
Are your wheels balanced?
Are the isolators in your foot boards in good condition?
That is about all I can come up with right now.
Old Aug 3, 2015 | 07:32 AM
Crashone's Avatar
Crashone
Check out the front motor mount and your swing arm bushings. EVOs are rubber mounted.
br549A1's Avatar
br549A1
A guy I know spent a year replacing all kinds of **** trying to get rid of a vibration at 2,000 rpms. In the end he spent a lot of money and got a sweet running bike but it will still shake his ***** on the seat like he's sitting on a paint can shaker at 2000 rpms. Smooth everywhere else though.
Old Aug 3, 2015 | 08:15 AM
texashillcountry
Dirt don't hurt
Not quite true.
EVO softails are frame mounted, all others are rubber mounted.
Old Aug 3, 2015 | 08:16 AM
texashillcountry
Dirt don't hurt
Got any ideas what he did?
Old Aug 3, 2015 | 09:06 AM
0maha's Avatar
0maha
Originally Posted by Jchaiyo
Ok so 1992 fatboy.
I want to understand...Are you saying that the shaking now is different than it was before, and that the shaking started after you adjusted the clutch?
Old Aug 3, 2015 | 10:04 AM
falconbrother's Avatar
falconbrother
I had a 1991 Heritage that vibrated awful. I carried spare hardware and blue locktite all the time. On more than one occasion I literally held parts on the bike while riding down the road.
Old Aug 3, 2015 | 10:17 AM
texashillcountry
Dirt don't hurt
I've got a '95 Heritage that is very smooth for a hard mount bike.
The one time I had excessive vibration it was in my feet.
I replaced the rubber pads on my foot boards and everything was fine again.
Old Aug 3, 2015 | 10:27 AM
Beemervet's Avatar
Beemervet
LOL........ he's talking about himself.
