Injectors, Red
Old Aug 14, 2015 | 06:31 PM
RLH3175's Avatar
RLH3175
Default Injectors, Red
I am thinking about changing my stock injectors on y 1996 Ultra Classic. From what I have read, I think the red ones may be the way to go. I have a stock engine with the EV 27 cam and the Patriot 2 into 1 exhaust. I may do the 89" S&S kit this winter and I would need them then for sure.
I started looking on line for them and haven't found any yet.
Old Aug 14, 2015 | 07:27 PM
Dr.Hess's Avatar
Dr.Hess
If you have the specs on them, they should be pretty easy to find. Any fuel injector shop would be able to look them up. You have some way to control the fuel maps, right?
Old Aug 14, 2015 | 08:21 PM
RLH3175's Avatar
RLH3175
I have the Power Commander 3.
I was hoping that it would be as simple as telling the Harley shop that I wanted injectors for the MM fuel injection for a 1996 EVO, the red ones.
Old Aug 15, 2015 | 09:00 AM
1997bagger's Avatar
1997bagger
http://www.ebay.com/itm/NOS-Harley-D...a06a16&vxp=mtr
Part number above, Harley used the updated 2001 injector with the SE Stage 3 kit and Harley parts deptments are down to someone that just needs a job, you really lock them up when you say Evo and they need to get a book.
The MM system won't support a 89" Evo, have been there, tried that and done that with modded plenoms, Red injectors, PC3, runs on the edge of being lean in the 40-50 mph throttle roll on area, actually heated a piston resulting in a hone and re ring. A CV carb with a Yost kit will out perform the MM in all areas except extreme cold start, a healthy 80" 89" is a different creature when the MM is replaced with a carb.
You can spend $1000 to $1500 on aftermarket EFI systems to say "I have EFI" supported by $350 for a dyno tune or consider $500 for a carb conversion that is solid as a rock on a Evo. You still have to ask yourself, will the pumped up aftermarket EFI hold it's tune, will the Dyno operator put effort into being perfect if the AFR's are all over the place when time is money.
Modern EFI left the MM system with updating in the dust and aftermarket continues to make money off altering current production items. 3 items that time passed and will always be there for you is a Evo, prehistoric drip carb and your dog, was going to say wife but they need traded in on newer models sometimes.
Believe I have some extra Red injectors laying around, will check and get back with you.
Old Aug 16, 2015 | 08:51 PM
1997bagger's Avatar
1997bagger
I have extra Red injectors, shoot me a fair offer
Gnassty
11
Mar 6, 2019 11:00 AM
Kingglide549
Nov 23, 2018 03:31 PM
MrCay
Jun 29, 2017 02:57 PM
Peggers
EVO
18
Aug 5, 2012 04:25 PM
1peter
21
Nov 2, 2007 02:49 PM
