Rear rotor bolts
Old Aug 29, 2015 | 12:59 PM
RHillbilly's Avatar
RHillbilly
Default Rear rotor bolts
Changing rear rotor on 91 softail anyone know the bolt size
Old Aug 29, 2015 | 01:28 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I want to say they are 3/8x16.
FWIW the bolts cost 99 cents each at your local dealership.
Old Aug 29, 2015 | 04:58 PM
RHillbilly's Avatar
RHillbilly
Thanks I will look at dealership seems like everything I try to buy they have to order I am almost sure they are 3/8 16 but not sure on lenght
Old Aug 29, 2015 | 05:07 PM
texashillcountry
Dirt don't hurt
I think they are 1.5" long.
If you have a paper parts manual it will tell you the thread size and length of every bolt and the size of every washer on your bike.
Old Aug 30, 2015 | 04:09 PM
grbrown's Avatar
grbrown
Wink
They are: "#4726 BOLT, 7/16-20 X 1-1/2 hex. hd. (Grade 5 steel)" and list price is just over a dollar each.
Old Aug 30, 2015 | 04:19 PM
RHillbilly's Avatar
RHillbilly
I went to Harley shop today they couldn't find them in their computer or should I say their computer couldn't pull them up,they have tapered head and are Allen head
Old Aug 30, 2015 | 04:20 PM
texashillcountry
Dirt don't hurt
Are you sure you aren't talking about the pulley bolts??
They are slightly larger than the rotor bolts.
Old Aug 30, 2015 | 04:28 PM
texashillcountry
Dirt don't hurt
Man I'm sorry I screwed up.
Are you running a mag or a spoke wheel?
The bolt size I gave you above is for a mag wheel.
The spoke wheel uses
3655A SCREW 5/16-18 X 7/8 TORX pan hd with a lock nut behind it.
Old Aug 30, 2015 | 04:35 PM
RHillbilly's Avatar
RHillbilly
Soliud rear wheel don't see any way to put bolts on guess I will pull bolts and go to hardware store and match them up,was trying to get everything before I start
Old Aug 30, 2015 | 04:49 PM
texashillcountry
Dirt don't hurt
These are the bolts you need for a mag wheel
43567-92 SCREW 3/8-16 X 1 TORX pan hd.,
