Primary leak?
Old Sep 25, 2015 | 10:14 AM
  #71
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Originally Posted by kp877
I'm going to be holding that front brake extra tight at intersections now waiting for it to pop at the worst possible time.
That would take all the fun out of a ride for me.
Fix it so that there is no play in that snap ring and you should be fine.
Old Sep 25, 2015 | 04:11 PM
  #72
apples402's Avatar
apples402
Maybe set the new snap ring in place with a touch of loctite in groove to help keep it from rotating for a little peace of mind?
Old Sep 25, 2015 | 04:19 PM
  #73
br549A1's Avatar
br549A1
Didn't think of that. Little green bearing retainer? Would that work?
Old Sep 25, 2015 | 04:26 PM
  #74
apples402's Avatar
apples402
That was my thought.
Old Sep 25, 2015 | 04:43 PM
  #75
br549A1's Avatar
br549A1
Like your idea thanks! Made me wonder if I should have blue loctite on the adjuster nut or not too. I don't have any on there. Does anyone loctite that?
Old Sep 25, 2015 | 04:49 PM
  #76
texashillcountry
Dirt don't hurt
No need for loctite.
The jam nut holds it.
Old Sep 25, 2015 | 05:09 PM
  #77
br549A1's Avatar
br549A1
Should. Didn't last time. Still think it's mad at me but I won't loctite it!
Old Sep 25, 2015 | 05:24 PM
  #78
texashillcountry
Dirt don't hurt
If it didn't hold you didn't tighten it enough.
Have you got a bent wrench to get a better grip or a socket with a nut welded on the end of it?
Old Sep 25, 2015 | 05:29 PM
  #79
br549A1's Avatar
br549A1
Used a wrench on the nut and an Allen in the other part. It's tight now. Book says 10 ft lbs but in sure it's tighter. How tight I don't know. I can get a box end on it fine just hits a nut every couple inches so I readjust it.
Old Sep 26, 2015 | 07:20 AM
  #80
WP50's Avatar
WP50
A drop of Loctite at each corner where the chunk is missing wouldn't hurt.
Have done a couple things similarly.
As pointed out that snap ring ain't right. If it's the right size it should be hard to even rotate it much less do what is in the video.
WP
