zerk fitting
Old Oct 15, 2015 | 08:44 AM
WVICEMAN's Avatar
WVICEMAN
Default zerk fitting
I changed all of the fluids in my 1985 FLTC and was looking for the zerk fitting so I could grease the neck bearing and cannot for the life of me find a fitting. Does anyone know where they located this fitting? Thanks
Old Oct 15, 2015 | 09:39 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Granted I have a '95 but mine didn't come with a zerk fitting.
It did have a hole in it so that I could install one though.
Does yours have a hole to put one in?
Old Oct 15, 2015 | 10:27 AM
WVICEMAN's Avatar
WVICEMAN
I didn't see one, I'll check it out this evening.
Old Oct 15, 2015 | 10:35 AM
Dr.Hess's Avatar
Dr.Hess
There is not one on my bike on the neck.
Old Oct 15, 2015 | 10:52 AM
Hackd's Avatar
Hackd
My 93 FLHS has one, it's a bit difficult to get to. I have to swing the handlebars to get the grease gun (with hose attachment) onto it.
Old Oct 15, 2015 | 11:44 AM
Beemervet's Avatar
Beemervet
Many do not have the fitting or hole. The fix is to use a left hand twist drill bit (avoids shavings in the neck) then tap the hole. The zerks are available at Lowes or any auto parts store in straight or angled. Be sure to not pump the neck plumb full of grease or you will be cleaning it off of your front fender all summer long.
Old Oct 15, 2015 | 03:18 PM
0maha's Avatar
0maha
"Cleaning"?
Heh.
Old Oct 15, 2015 | 04:36 PM
bagga's Avatar
bagga
my 85 flhtc doesn't have one. the only time it's been greased is when it was assembled 30 years ago. i don't worry about it. if the bearings go out i'll replace them.
Old Oct 15, 2015 | 05:12 PM
Tom84FXST's Avatar
Tom84FXST
A left hand bit will get just as much metal in the neck as a right hand bit...period
On a bike that is stored out of the rain, the grease will last a really long time...bearings going out on the neck will give you lots of warning...not an over night thing...if the bearings go out, when you have it apart is the time to add a grease fitting.
Old Oct 15, 2015 | 07:28 PM
glidein wide's Avatar
glidein wide
