cutting stock pushrods
Old Nov 1, 2015 | 07:26 PM
langwilliams's Avatar
langwilliams
Default cutting stock pushrods
Hi, I've seen conflicting info reading up in prep for my cam change....seems like I saw where the lifters have to be on the base lobe before cutting the pushrods an I've read where others just cut all 4 at once....does it matter, is one way preferred? thanks for any help!
Old Nov 1, 2015 | 07:33 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Cut all 4 at once (if that is what you're gonna do) but make sure you use small bolt cutters to do it.
What ever you do don't use a grinder to cut them!!!!!!!!!!!
Old Nov 1, 2015 | 07:36 PM
Stiggy's Avatar
Stiggy
The point of base circle is to relieve the pressure that's on the rods as you cut them. I think its easier to rotate the motor to get there rather than all 4 at once. (Bolt cutters.)
Old Nov 1, 2015 | 07:45 PM
texashillcountry
Dirt don't hurt
Cutting all 4 at once won't hurt anything.
I did mine that way.
Old Nov 1, 2015 | 07:48 PM
langwilliams
LOL just like I've read....conflicting opinions! thanks....nice to know I'm good either way. I have to borrow bolt cutters....I'm hoping my future son in law gets his snap on bearing puller set soon so I don't have to go rent one.
Old Nov 1, 2015 | 07:49 PM
langwilliams
also......when installing the bearing...you install it so you can see the writing facing the cam?
Old Nov 1, 2015 | 07:58 PM
WP50's Avatar
WP50
Don't think it can go but one way, Needles to the cam
WP
Old Nov 1, 2015 | 08:19 PM
Racepres's Avatar
Racepres
Oddly...I still have the stock pushrods that work just fine with my new Cam!!!!
BTW...The cam bearing can go either way...but needs to go facing the writing because it is manufactured to Push on that end...thicker cup...
Old Nov 2, 2015 | 05:12 AM
br549A1's Avatar
br549A1
Writing facing you on the cam bearing. Also make sure if you aren't using a bearing installer that you don't sink it too far. I sunk mine to the shoulder and ended up renting the tool again and buying another bearing. The install tools have a lip so they won't sink it too far.
Old Apr 11, 2019 | 06:16 AM
Fuego1340's Avatar
Fuego1340
Stage III
Can I ask why you shouldn't use an angle grinder? I'm asking because I already have lol. I plugged up the push rod holes with rubber gloves before doing so if that counts.
