I have been using the chrome Fram PH6065B from Walmart, like ten bucks. I also use the Valvoline 20-50 motorcycle blend, also at Wally World. Been using this mix for years over several bikes. I am as **** about oil changes as anyone I have ever met. Clearly the brand isn't a hang up but, I don't go real far between changes.
I heard twinky's and evo have the same filter but on has larger filtering holes.
While both filters fit onto either...it is Decidedly Not Correct to interchange them..The 348 has a smaller micron rating, and an anti-drain back valve...both undesireable for yer Shovel or Evo. OK for Twinky because they filter the Feed [Pressure] side of the pump...
I continue to use the 51215/1215!
