Well here's my issue. Bike is a 96 FB with just over 13,500 miles on it, bought it in May with 9,000 so bike sat a lot over the last 20 years until I got it. Bike runs awesome, I just did an 800 mile trip two up with the wife and it ran perfect. Just about 1500 miles ago I started going through oil and began noticing smoke when id come to a stop light but only at night cant see it during the day. Guys I ride with say they dont see smoke otherwise when they're behind me and I dont see it on start up. I'm using about a quart every 5-600 miles. Did compression test and got between 160-165 front and back. My plugs look good, rear plug has a little oil on the bottom couple threads but barely anything. I'm thinking valve seals/guides? I was gonna pull the heads this weekend and get them checked out but thought id run it by you all here first and see what everyone thinks?
Reason: Updated
Oh also I live in far northern cali and there's no shops near me so I'll be shipping the heads out to be looked at/repaired. Can someone recommend a place for me to send them too? Thanks!
When you get your exhaust off you should see an oil trail in the exhaust port, if it is valve seals. Another member here just replaced his seals and lapped his valves at home, maybe he will chime in shortly.
Don't go and do no Home brew crap....Either do the entire top end [Correctly]...or Ride it..It sure ain't got no miles on it...Change to a different Oil...don't care what...just different Oil......
Me...I ride 'em till they absolutely need help...then...I rebuild the Whole **** and Shebang....Ride...Repeat.
No idea about home brew crap, although I do love a good home brew! Guess I look at it differently far as if somethings wrong with my bike im gonna fix it. If I have to do the whole top end I will, but if I just have a bad valve seal(s) then why not pull just the head(s) and fix it? Im not interested in taking a quart of oil with me on every out of town trip or a bike that smokes. Thanks for chiming in though!
I would pull rocker box covers and check oil returns are clear and not causing the oil to pool up there. Usually bad valve seals will smoke at start up it sound more like could be your rocker box if filling up And the the excess is being sucked out through the breather tubes.
With that compression it shouldn't be coming past the rings, most likely valve seals or the umbrella seals. Pull the hose off the head breather that goes to the air cleaner and see how much oil is coming out of it. You can put umbrella seals in it without pulling the heads, work a look
