Evos with FI
Old Nov 14, 2015 | 11:32 AM
RLH3175's Avatar
RLH3175
Originally Posted by brad75raiders
I had efi on a 97 that failed 77k I swapped it out with a used S&S carb and intake off of eBay 100$ new cables 50$ and a tank petcock adapter kit for 65$ the carb even had a thunder jet
So it can be had for cheap. A power commander 5 will run you 350-400$
Auto tune another 2-300. Then you get to dyno....you guessed it 3-400$ . That's IF the fuel injection MM is working properly. That's why I ditched the efi.
I got new, the PC V, The PC Auto Tuner, and the PC Data Logger for $850 from Amazon
With the PC Auto Tuner, I tell it what AFR we want the engine to run at.
Map for Cylinder 1
Map for Cylinder 2
And the data log shows how it is working
File Type: xls
Old Nov 14, 2015 | 11:56 AM
im's Avatar
im
It is a very simple system.
Unfortunately, most folks refuse to read the one chapter in the Harley service book on fuel injection.
Again, it is a simple system.
Some folks went as far as changing to carb because of the inability to trace a simple problem like the loose electrical connection for the crank sensor.
M & M fuel injection was used on some bikes from about 1995 to 2001.
Since it was later replaced by Delphi some mechanics are much less experienced with the system.
A simple loose wire, failure to clean ECM connections or dirty throttle body caused much frustrations to some.
If you research Magneti Marelli you will have a greater understanding of that company.
Used in may pricey applications.
Parts are available.
The most difficult part to obtain is a gas tank but they can be obtained.
The engine temp sensor, cam position sensor and making sure to keep the throttle body clean are probably the most common service.
Heck, even carbs are viewed as unusual by some young mechanics.
Many are still on the road.
Old Nov 14, 2015 | 03:25 PM
brad75raiders's Avatar
brad75raiders
I went to a 127ci the fi couldn't keep up stock it's ok but anything hot forget about it.
Old Nov 14, 2015 | 03:56 PM
Crashone's Avatar
Crashone
My 96 Road King has the EFI system, a head temp sensor went out and I just replaced a cam sensor that was melting. If the price is right pick it up and ride hell out it. Stash a few bucks away as you go towards the conversion and keep hitting it. I've logged over 10,000 on mine since I bought it and do not regret it at all. My 96 does not have a tunable ECM so I am thinking about the S&S module GRBrown has spoken of.
Old Nov 14, 2015 | 04:35 PM
rockhousebadboy's Avatar
rockhousebadboy
I have a 97 FLHTCUI with 98K and counting. I have replaced Failed Engine temp sensor at about 75K, Air Intake temp at 83K and also replaced Cam position sensor when I did my top end rebuild and cam swap last winter at 91K, because it had a little oozing of the sealant and for piece of mind but it was still working correctly. If you don't plan to go crazy with the motor, its a fine system and as other have said fairly easy to trouble shoot IF YOU DO YOUR HOMEWORK....Would buy another in a heartbeat.
ultimo-hombre
Exhaust System Topics
Jul 21, 2025 12:24 PM
pwal
Dec 12, 2015 09:25 AM
horse55
EVO
Nov 10, 2013 06:11 PM
DavidStiebel
Jan 8, 2012 08:15 AM
motown
Jun 4, 2011 07:47 AM
