CV Carb Issue
Old Dec 24, 2015 | 10:20 PM
Ozark Joe's Avatar
Ozark Joe
Default CV Carb Issue
I took the bike out again to test it out. When I got back the carb was pissing gas from the overflow valve and elsewhere. This it happened just as i got in the garage and turned off the petcock. So it's not the petcock this time, I guess it's time for rebuild.
Old Dec 24, 2015 | 11:10 PM
langwilliams's Avatar
langwilliams
the easy thing to try is pulling the bowl an checking for junk. There's a needle that sits on the float that shuts off fuel flow an if it's not seating fuel will flow (at least that's how I understand it). I don't know much about anything but debris in the carb is the cause of a lot of the problems.
Old Dec 25, 2015 | 12:13 AM
Son of PMS's Avatar
Son of PMS
Stuck float, or worn float valve, or dirt in the bowl.
Old Dec 25, 2015 | 12:58 AM
Spanners39's Avatar
Spanners39
Or incorrect float height....
Old Dec 25, 2015 | 07:56 AM
Ruggs59's Avatar
Ruggs59
You sure did pick the right Forum Handle name, Every time i log in you have a different issue. Hope you get it sorted out... Merry Christmas.
Old Dec 25, 2015 | 08:12 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Things to buy: New needle, Polishing Compound, and Q-Tips.
Use the polishing compound and Q-tips to clean the needle seat.
Replace the needle and set float level.
Note: Don't use Rubbing compound as it is too gritty and coarse.
Old Dec 25, 2015 | 10:42 AM
Ozark Joe's Avatar
Ozark Joe
Usually how the ball bounces in my yard.
Old Dec 25, 2015 | 10:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Drop the float bowl, give a shot of carb cleaner into the needle and seat, replace float bowl.
Old Dec 25, 2015 | 11:12 AM
WP50's Avatar
WP50
Well ya got the best suggestion to start with.
What THC mentioned is a very good idea
WP
Old Dec 25, 2015 | 07:58 PM
14GuineaPig's Avatar
14GuineaPig
If you want to take a chance on a quick fix try leaving the petcock in the off position and starting the bike. Let it run until it dies due to lack of fuel. Then open the petcock and start the bike. This will work sometimes if there was a piece of dirt stuck in the needle and seat assembly. Sometimes it will flush the dirt out of the needle and seat and it will work properly again.
Maughanaj
Sep 23, 2017 01:30 PM
01 chopper
EVO
Apr 8, 2013 05:06 PM
berndog
Shovelhead
Jul 25, 2011 06:57 PM
75sporty
Ironhead
Jul 8, 2008 10:03 AM
panshovel4life
Shovelhead
14
May 26, 2008 10:25 AM
